Home > Technical > TD5 front brakes
Procta
TD5 front brakes
are these any better than the standard solid setup at the front? I recon the defenders going to fail on the fronts, got an imbalance, which was " corrected for the MOT" I really think its had a bent MOT put on it, we did sort out the suspension, how can a car pass with a leaky damper?? Laugh was they replaced the two turrets for the test, and then passed it, We have since replaced the full works anyway. So its going to be interesting on what the tester I use picks up! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #623852 13th May 2017 3:45pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I upgraded mine to vented discs and calipers stops on the button now
03 td5
I have a set of new front vented calipers for sale if interested discs are fairly cheap
 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #623854 13th May 2017 3:59pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Vented fronts are good, I'm putting a set on my 90 V8 Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #623876 13th May 2017 5:47pm
Procta
sounds good to me, pj2106 I will see what happens with the MOT, I have got a full blown kit on ebay I am watching. I will be doing the rear discs too, just that the full works is new. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #624111 14th May 2017 6:48pm
I stuck vents on my v8 90 only last week, I originally bought a fully reconditioned military axle which came with new brakes, though solids. With it being an auto, it's quite heavier on the brakes than a manual, so after 400 miles I decided change them. QRZ 2e0vpf
Post #624120 14th May 2017 7:21pm
pj2106
No worries procta let is know how you get on I would recommend genuine calipers over some cheaper makes from experience pistons tend to faulter on cheaper ones 2008 110 2.4 XS Utility (Hagrid)
Post #624145 14th May 2017 8:09pm
