Home > Td5 > Is it ok to drive without the front prop shaft ?
Defender marto
United Kingdom 2004 Defender 90 Td5 HT Oslo Blue
As title says is it ok to. I am trying to find out where the vibration is coming from. It all started when I took the landy in to have a transfer box seal done, the seal that sit between the tranny and gear box. It started of as being a noiseless vibration kicking in at about 50mph and dies away when you go below. Last Friday I took it back to the garage to have it looked at and they said they greased up the uj's and sliders and it is happens again you will need new uj's or propshaft as they don't cost much. Since then the vibration has changed. When starting from stationary the drive feels a bit lumpy until you get to just over 35mph then I get a noisy vibration which then disappears just as you hit 40mph and it is ok till the speed drops to 35mph again. This weekend I changed the rear propshaft and it made no difference at all. So rather than going out and spending on another propshaft is it ok to drive without the front one. If it is and it still vibrates then I can only asume it is the tranny box which is at fault. Thanks for any replies. Marto
Post #624069 14th May 2017 4:13pm
Yes, it's a pretty standard way to diagnose this sort of thing. With the diff lock engaged, of course. Darren
Post #624073 14th May 2017 4:23pm
Defender marto
Thanks for the reply. Diff lock engaged means in 4wheel drive, but in my case with no front prop. Is it ok to drive without it for a few days as if the rain stops and let me take it off I will not be bothered climbing underneath is again till next weekend
Post #624074 14th May 2017 4:29pm
roel
It is no problem to drive that way. You might hear some more cloncks as there is some more play in the driveline. So be a little easy with the clutch and it will do no harm.
I drove my Disco 1 back from middle Germany when my rear diff didn't like it anymore so I took the halfshafts out and the rear propshaft and drove home that way. Roel
2003 90 Td5 (2009-now)
Post #624076 14th May 2017 4:39pm
bankz5152
Yep. I drove back from france fine with a blown diff!
Post #624081 14th May 2017 4:51pm
Your Defender is permanently in 4wd but the diff lock physically locks the centre diff so that power is split 50/50 all of the time.
Yes, it'll be fine to drive like that for a while as long as you don't go mad or try anything like towing. Darren
Post #624082 14th May 2017 4:52pm
Defender marto
Thank so for the replies. I have taken off the front prop and taken it for a test drive, well once I engaged diff lock anyway would not move till I did as as stated there where a few more noises but no vibration. Having a look at the prop the uj's seem fine but the slider bit was very stiff and took a bit of force to get it to move. Took note of how it all lined up and pulled it apart and cleaned it up and re greased the tube but still a bit stiff. Put it back on and drove it again and it made no difference at all. Do you think it needs a new prop shaft or could it be something in the axel now?. Marto.
Post #624108 14th May 2017 6:41pm
It could quite easily be the prop. The problem is that testing them off the vehicle can sometimes not show any problem as it can be difficult to mimic the loads applied in situ. Darren
Post #624193 14th May 2017 9:52pm
Defender marto
Looking at new prop shafts now cheapest option for now and take it from there. What is a wide angle propshaft. And do I need one, or just stick with original. island4x4 sell it slightly cheaper that a normal prop. Marto
Post #624199 14th May 2017 10:13pm
There will, if anything, be less play and slop in the driveline rather than more, since any backlash in the centre diff and front axle will have been eliminated.
Just be aware that the vehicle may handle differently especially in slippery conditions.
Post #624206 14th May 2017 10:27pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
mine was exactly as you describe on my td5 90
the slider was seized and the prop was lined up in phase.
The new one is out of phase and I have no vibrations 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #624212 14th May 2017 10:40pm
Defender marto
What is this phase you mention?
Post #624237 15th May 2017 8:37am
agentmulder
Kuwait
UJs are more complex than I claim to understand but I do know that they do not transmit torque/rotational motion equally around a full rotation.
The two UJs can be aligned such that the oscillation effect is minimised (which is how your UJs are currently set up). If however someone pulls the sliding joint apart and then puts it back together in any different relative rotation between the UJs the oscillations will increase.
Phased = UJs 'correct' with respect to each other.
I'm unsure how this helped Gazman, maybe I misunderstood? Solved the bowel problem, working on the consonants...
Post #624242 15th May 2017 9:36am
Balvaig
Prop shafts are balanced from new and when you remove them you should mark the mating faces and refit to these marks. If they have been removed in the past and not marked , or are worn, then you can get vibration. If I remember correctly, you can refit with the mating faces rotated by 90 degrees. This can sometimes bring them back into balance and solve the vibration.
Post #624254 15th May 2017 10:32am
agentmulder
Kuwait
Due to the yokes the bolts centres aren't equally spaced on my 2.4 puma so I cant do 90°.
Only 180°, so two options each end = 4 possible installs.
Are the diff ends really 'matched' with the TF box outputs like that? Would 180° out on both ends make it OK again??
How much do the balancing weights play in to the phasing consideration? Solved the bowel problem, working on the consonants...
Post #624262 15th May 2017 11:02am
