Home > Technical > A quick question about grease
gilarion
My tub of grease ran out today so a quick trip to Halfords for a new tub. However the only grease they stocked was CV & Lith-Moly Grease. The grease I have always used is Multi-Purpose grease.
Now my question is this, will CV & Lith-Moly Grease be OK for greasing the prop shaft and the U joints. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #624043 14th May 2017 1:56pm
Yes Thumbs Up
If it's the Comma one, it says multi-purpose on the tub. Darren
Post #624044 14th May 2017 2:05pm
gilarion
It is the Comma one but does not say general purpose the tub looks like
Says
A lithium based CV Lith-Moly grease of Number 2 (medium) consistency, containing Molybdenum disulphide. Ideally suited to use in constant velocity or homokinetic joints. Not to be used on wheel bearings.
Lithium-based grease, containing Molybdenum disulphide. Specially formulated for use in CV joints.
High in extreme pressure additives to give long life under heavy loads.
Chemically compatible with polymeric boot material.
Includes a laminar solid lubricant which overcomes boundary lubrication.
Good corrosion protection – Rust inhibited to protect bearing surfaces. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #624048 14th May 2017 2:21pm
Hmm, ok. It's hard to believe it's any different from this one pictured on the Halfords website:
http://www.halfords.com/motoring/engine-oi...rease-500g
I think they've just got different versions of the same pack as the Comma website shows a slightly different one again.
They all seem to mention 'multi-purpose' somewhere though, so I wouldn't worry about it.
http://www.commaoil.com/passenger-vehicles...ategory/11
 Darren
Post #624071 14th May 2017 4:21pm
roel
Wheel bearings need different grease than multipurpose grease. Roel
2003 90 Td5 (2009-now)
Post #624079 14th May 2017 4:42pm
zsd-puma
CV joints usually use a slightly more runny grease. It'll likely get chucked out of UJ's quickly
Comma specify this;
http://www.commaoil.com/passenger-vehicles/products/view/210
For the propshafts.
What you've posted above is this;
http://www.commaoil.com/passenger-vehicles/products/view/212
The CV will probably work, but not be ideal. It's just like engine oil, any engine oil is better than none, but it's always best to use the correct one.
Post #624131 14th May 2017 7:45pm
williamthedog
I use jcb blue grease for the props, have done for years Thumbs Up
Post #624154 14th May 2017 8:23pm
gilarion
Thank's guys, I did have my doubts, so it's back to Halfords for an exchange. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #624196 14th May 2017 10:04pm
