Home > Maintenance & Modifications > Any tips for rear door card removal on a 2016 90SW?
m33ufo
Wales
I want to remove the original wheel carrier from the back door. I had assumed a 2 minute job but then of course it's never that simple and looks like I'll have to remove the door card to access the nuts.
So, inner handle off, what next? I don't want to force it too much!
Looks like there's a cover under the internal door lever - does it need to come off?
Thumbs Up 110 DCPU
Mark
Post #623866 13th May 2017 5:22pm
gilarion
I have never had to remove the inner handle to remove the door card just remove the fasteners and slide it over the lock it should take minutes. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #623869 13th May 2017 5:32pm
Balvaig
Yes pop out the cover on the door handle.
Remove screws from grab handle and remove.
Now the tricky bit. You need a trim removal tool preferably. You need to pop out the plastic trim retainers located around the edge of the door card. Carefully pulling the card with fingers helps to identify their location, and the trim tool will pop them out. if you don't have a trim tool then you can use a broad flat bladed scewdriver or get your fingers under the card and pull. You do run the risk of breaking the clips or the plastic card though.
From memory there is a retaining clip in the centre of the door card which can be carefully pulled off.
Not a big job, but does require care - replacement door cards are expensive Big Cry .
Post #623871 13th May 2017 5:35pm
m33ufo
Wales
Thanks both.
I do need to get a trim popping tool. I never have one when I need one which is surprisingly often Smile Hoprfully a knife from the cutlery draw covered in masking tape will suffice - I'll give it a go in the morning. The dog has dragged me to the coast Thumbs Up 110 DCPU
Mark
Post #623880 13th May 2017 6:34pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
A nice warm sunny day will be ya friend also,
Plastic moves and bends better when warm,
In general I don't do ANY trim removal unless all is warm Thumbs Up
Post #623927 13th May 2017 9:39pm
zsd-puma
Definitely need a trim removal tool, one of those was the best investment i've ever made in a tool i think.
You can do it without one, but you'll likely end up breaking either the clips or the moulding on the door card that the clips fit into.
If you ever removed one of the side door cards, then you definitely need a tool for those anyway, as they always break if you don't use one.
Try not to get the all in one tools, the ones that look like a nail puller (like the back of a claw hammer) are the most versatile, athough i've also got one of the plier type ones and they're quite good for door cards.
Post #623965 14th May 2017 5:39am
m33ufo
Wales
The quality varies so much with these things - it's good to get a specific recommendation. I like the idea of the nylon kits to minimise damage/scratches. 110 DCPU
Mark
Post #623968 14th May 2017 6:04am
zsd-puma
The plastic ones are a bit too fat really, they tend to break the door cards more as the ramps on the ends of them are too steep.
I had a metal Sykes Pickavant one, but it seems they're no longer available.
I've also got this set, they're not bad;
http://www.ebay.co.uk/itm/CT1576-4PC-Door-...Swv0tVTJe5
Cheap and cheerful, but they work quite well.
Post #623970 14th May 2017 6:12am
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
For when you are removing the door card... here's the location of the trim clips to be aware of.
A trim tool is a valuable friend!
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #624102 14th May 2017 6:03pm
m33ufo
Wales
What a top man.....ordered a tool this afternoon!
Thumbs Up 110 DCPU
Mark
Post #624109 14th May 2017 6:47pm
YOLO110
Australia
I wonder if the RHD door clip location is the mirror image of that LHD one? YOLO... You Only Live Once...
Post #624190 14th May 2017 9:46pm
m33ufo
Wales
Whistle 110 DCPU
Mark
Post #624197 14th May 2017 10:05pm
CDN38
There is only 1 way the tail door opens. Hinges on the vehicles right side.... (no RH or LH side) However, with the first and second row door cards, the clips are mirrored from side to side. it's a Landrover thing...
Post #624198 14th May 2017 10:10pm
mk1collector
Err, no Whistle Ray
My build thread
Post #624200 14th May 2017 10:14pm
Delintely use tapes to protect the paint or it will chew it badly, as mentioned earlier.
Warmer weather is indeed a good idea, and when you do it go easy. Use just enough force to remove it one by one.
Take you're time, no rush.
To much force too fast will create breakages.
But I've had mine off of all doors and back on with no problems at all with any door cards.
If anywhting the front are more tricky. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #624207 14th May 2017 10:27pm
