Home > Series Land Rovers > Removing 109 6cylinder head
excossack
I have a 6 cylinder head to remove with a friend, having not done one before, is there a short guide on the steps to remove one? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #623844 13th May 2017 3:09pm
excossack
After removing 20 odd bolts, we think we have them all. The head is still firmly attached (not run for many years and engine appears seized)
Any tips on removing a stubborn head?
Also, any ideas on the size of the nut for the bottom pulley? 1999 Defender TD5 110
Regards
John M0VAZ
Post #624270 15th May 2017 11:12am
It's a long while since I took the head off one of these! The 1.6 and 2.0 four cylinder, and 2.6 six cylinder IOE engines are essentially the same.
As I recall all the head bolts and studs are obvious, so once the inlet manifold and rocker shaft is off and the head bolts removed the head should be free. There is an external oil pipe at the rear of the head which sometimes gets overlooked. If the head is stuck you could try giving it a good biff with a hardwood block on a solid area.
I'm afraid I can't offhand remember the size of the bottom pulley retaining bolt, but it will probably be a Whitworth/BSF sized socket. I know that I have a 3/4" drive socket that fits, if you could measure the AF dimension with reasonable accuracy I can translate it to the approprate tool size for you.
It's a cracking engine when in good condition, by the way, exceptionally smooth and by the standards of the time quite powerful. Also quite scarce now.
Post #624275 15th May 2017 11:43am
excossack
Cheers for the reply.
The rocker shaft is still in place so maybe this is the key bit we missed.? 1999 Defender TD5 110
Regards
John M0VAZ
Post #624276 15th May 2017 11:48am
excossack
A picture of the head
Regards
John M0VAZ
Post #624278 15th May 2017 11:50am
Goodness, it shows how long since I messed with one of these, I had fogotten that the rocker shaft runs directly in the head.
You've removed the nuts on the two studs that hold the cover on, I presume?
Post #624283 15th May 2017 12:17pm
excossack
The ones circled in yellow?
Regards
John M0VAZ
Post #624287 15th May 2017 12:26pm
I was meaning these (below), I *think* they go right through the head.
I have the 2.6 WSM at home, I'll have a look for further clues this evening.
Post #624290 15th May 2017 12:35pm
excossack
Ahhh right. We thought those are just studs for the rocker cover.
Appreciate if you can have a look in the WSM
cheers 1999 Defender TD5 110
Regards
John M0VAZ
Post #624292 15th May 2017 12:37pm
dorsetsmith
ideas on the size of the nut for the bottom pulley 1``13/16 socket deep I think
Post #624294 15th May 2017 12:46pm
cheers
You're right and I am wrong, they don't hold the head down.
You might find these links useful:-
http://www.landroverweb.com/Pdf-files/Manu...Part_2.pdf
http://www.landroverweb.com/Pdf-files/Manu...Part_3.pdf
The 2.6 engine starts on page 50 of the part 2 PDF and continues in Part 3. Both of these links are from here:-
http://www.landroverweb.com/landrover/pdf-land-rover-manuals/
... which has a useful selection of PDF manuals.
It seems as though you're head may simply be stuck, in which case the usual techniques of biffing with a wooden block, lifting with an engine crane under the thermostat housing, or lift and biffing in combination, may be the recourse.
Post #624298 15th May 2017 1:11pm
excossack
Looking at the WSM. I think we have missed out possibly 2 bolts, the ones circled in yellow which look to go into the block as well, which if we have, wont help much! 1999 Defender TD5 110
Regards
John M0VAZ
Post #624310 15th May 2017 1:39pm
excossack
Finally got the head off just the three middle rocker bolts holding the head in place.
Cheers BW for the link to the PDF WSM. 1999 Defender TD5 110
Regards
John M0VAZ
Post #627126 26th May 2017 9:18pm
excossack
The cylinder head will be making progress over the water to a new life in Texas! 1999 Defender TD5 110
Regards
John M0VAZ
Post #630192 9th Jun 2017 2:07pm
