Home > Technical > Help please
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Help please
Apologies if there is already a thread, I've not had a chance to search.
Driving home and I've just suffered loss of drive, I've had a bit of noise in the drive train (sounds like front passenger corner) changing up and down over the last couple of days (a bit of feedback through the clutch pedal too). This has just resulted in a louder noise and loss of drive. Now getting a grinding/wirring noise from that corner.
I suspect it's in the shaft supplying drive from the front diff to front wheel but haven't been able to check yet or try moving it with diff lock as I'm sorting out the kids post school.
Before I phone landrover assist (covered by extended warranty) is there any thing obvious I should check. Should I consider getting it looked at by the dealership (warranty) or local independent? Its a MY 2012 with 35K miles
Thanks in advance for any help.
Keith Keith
Post #623659 12th May 2017 5:12pm
mk1collector
Drive flange splines stripped. Ray
My build thread
Post #623662 12th May 2017 5:23pm
Keith5
I did wonder if it might be something like that, but wasn't sure exactly how it was setup.
Will try driving with diff lock and see how I get on.
Hopefully covered by extended warranty. Keith
Post #623664 12th May 2017 5:26pm
ickle
diff lock in and it should drive, does sounds like drive flange
Check whether your stealer considers drive flanges warrantable or a wearing / replaceable part.
Post #623667 12th May 2017 5:33pm
mk1collector
I wouldn't have thought it would be under warranty. Take the wheel off and bolt a new one on yourself, they are only about a tenner and 15 mins to fit tops, taking it slow. Ray
My build thread
Post #623668 12th May 2017 5:35pm
Keith5
Thanks for the feedback, not sure I want to ask but what if it diff lock wont engage/make it drive? Keith
Post #623669 12th May 2017 5:46pm
zsd-puma
if the Diff lock wont make any difference then it's likely the adaptor shaft from the gearbox to the transfer box, which has failed, same issue of splines failing, but in a different place.
Either will be covered under the warranty, they're not a consumable part like a clutch, if your dealer says otherwise go above their head to LR customer services.
I wouldn't waste your time checking anything if it's under warranty, just get LR assist out and have them take it to the dealer, it's what you pay them for (via the warranty).
Post #623683 12th May 2017 6:51pm
Keith5
Diff lock has made no difference and based on being noise free when idling in neutral it appears to be gearbox/transfer box.
Landrover assist have confirmed that it doesn't drive so have arranged recovery to the dealership.
Thank you for the comments so far, lets see what tomorrow brings. Keith
Post #623748 12th May 2017 10:15pm
zsd-puma
Failed adaptor shaft splines then.
Post #623778 13th May 2017 5:47am
LR90XS2011
get them to fit the Ashcroft kit or you will be doing it again in another 35K DEFENDER 90 TDCI XS,
Post #623780 13th May 2017 6:26am
Keith5
Ashcroft would be nice however would a warranty repair not be genuine parts only? Keith
Post #623781 13th May 2017 6:52am
Keith5
Update from the dealer today. Landrover have approved a replacement adapter shaft under extended warranty. As they needed to take the transfer box out to investigate I'm assuming this is the shaft between gearbox and transfer box.
Thanks for the guidance at the end of last week gents. Keith
Post #624796 17th May 2017 10:03am
