Home > Maintenance & Modifications > Brake Upgrade for Puma
Page 2 of 3 <123>
leeds
Might be worth a phone call to David at Llama 4x4
Website is llama4x4.com
I know he does brake hoses etc.
HTH
Brendan
Post #62366 5th Mar 2011 10:48am
Alive Tuning
landy andy wrote:
My next mod will be to change calipers to 110 ones and vented discs.
The front calipers are the same on both 90 and 110. The only exception to this is if you have solid front discs, rather than vented front discs.
The defender 110 (with rover axles) rear brake calipers will fit on the back of a 90, but you'll need the slightly larger diameter 110 rear discs as well.
I'm not 100% on this, but I believe the rear calipers from an early type salisbury axle are slightly different to the later type rover axle, and are not interchangable.
Post #62389 5th Mar 2011 4:46pm
dgardel
Italy
nakatanenga wrote:
1) Useful upgrades: cross drilled discs, braided hoses, Ultimax pads etc give better performance. Also the use of an ABS type brake booster are all little by little helpful but are not rocket engeneering.
2) An additional electric brake pump gives impressive stopping power....
Martin
could you provide me more infos about 1) and 2) ? Thumbs Up Thumbs Up
ciao
Daniele (Virus - The Martino M. friend) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #62407 5th Mar 2011 7:46pm
landy andy
I have solid front discs, that I have changed to grooved and cross drilled. So the next step for me is vented, cross drilled, grooved discs.
Thanks for the info Gary
Andy
Post #62415 5th Mar 2011 9:18pm
T1G UP
Bells and rotors are fantastic, alot lighter and much better cooling but can be expensive.
Post #62416 5th Mar 2011 9:24pm
Alive Tuning
Here's some pics of my brake conversion for the Defender. Extremely powerful, very well balanced, but not that cheap!
Post #62569 7th Mar 2011 12:57am
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
An easy modification to improve the power of brake is to install the servo brake of Discovery 2, a friend of mine has did this on his 110 td5 used in Africa.
 Matteo
Defender 110 Td4 SE MY 09
Post #62596 7th Mar 2011 12:07pm
MK
HTH
Brendan
Did not have a good experience. I got some of his shoxs and he did not want to change a pair of faulty ones Evil or Very Mad Puma 110" SW
Post #62598 7th Mar 2011 12:12pm
Alive Tuning
This will give improved braking effect of course, but will also cause the onset of brake fade to occur much more rapidly.
Post #62600 7th Mar 2011 12:15pm
Bomber82
Gary the fading is the formation of gas, produced by hot pads, which creates a cushion between pad and disc, reducing friction.(I know you know better than me! Wink )
I can not understand where is the relationship with improving the servo brake, considering that I don't use my 110 for race, because the improve is the strength to tighten the pads on the disc.
We could obtain the same result with a caliper more powerful, without changing discs and pads...or not?? Matteo
Post #62952 9th Mar 2011 5:54pm
Alive Tuning
Bigger discs give more surface area, for larger pads to bite onto. The larger the disc diameter, the greater the stopping power.
I use the Hi-Spec brakes using the standard (ancient) defender servo, and the pedal feel is superb. The choice of pad material makes a difference to pedal response too.
Post #62988 9th Mar 2011 8:28pm
Naks
how does this affect TC? Surely the TC has been programmed for the OEM brakes? --
Post #63056 10th Mar 2011 8:17am
Alive Tuning
ABS/TC just uses special rings, which fit into the hubs. We've fitted our Hi-Spec brakes to defenders with TC. Indeed we have a 2009 Puma 110 XS in the workshop right now, having this very conversion. Very Happy
Post #63057 10th Mar 2011 8:21am
Naks
What I'm interested in is how the improved braking power affects TC - does it make TC better/worse/same? --
Post #63058 10th Mar 2011 8:24am
Alive Tuning
Bigger brakes imporve braking performance and pedal feel, and so can prevent the wheels from locking, through better brake control. You won't have to apply so much pedal pressure, like you would with standard brakes.
ABS/TC will work in exactly the same way, but in theory should come in less often as you can feel what the brakes are doing more.
Post #63059 10th Mar 2011 8:31am
Page 2 of 3 <123>
