![]() | Home > Puma (Tdci) > MAF Sensor problem (I think), code p0100 |
TIM S Member Since: 11 May 2017 Location: Peak District Posts: 3 ![]() ![]() |
I have had similar problems diagnosed as out of range injectors ECU and wiring faults and MAF sensor failure. No-one seems to be able to diagnose this beyond trying out replacements, which gets very expensive. Did you get anywhere?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20980 ![]() ![]() |
Pretty sure that is the nuisance one.
Clear it and forget it. You could also give you're MAP and MAF a clean, I was surprised how easy it is to do and how dirty they can be. This code is often brought on by a Snorkel in some cases I've heard, but I have one and have had zero issues. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
tracstiling Member Since: 15 Jan 2017 Location: uk Posts: 2 ![]() ![]() |
Hi, have fixed the problem. It was the wiring loom. It had chaffed/rubbed in a few places which caused the false MAF readings. You need to take the loom tape off and just check for signs of wearing and repair the area/s. Mine had two areas of wear. Hope this helps. Regards Steve
Thanks. I'll try that at the weekend.
Can you tell me where you found the problems in the loom on your car? I'd guess this is a defect due to the design and positioning not a random wear issue.
