Home > Puma (Tdci) > High/low range switch on Puma LT230
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Hi all, looking for some insights...
On the TD5, some people would shunt or disconnect (depending on... MY?) the high/low range switch on the transfer box, as this changes the throttle response.
On the Puma, I think it also changes the anti-stall logic and keeps the EGR closed (is that actually true?), so I wondered if anyone has done that on the Puma and what has been the outcome/benefits.
If I was to do it, I'd rather do it "properly" by fitting a switch in the cabin, so I'd need the right connector to plug the wire from the ECU, i.e the one found on IGM500011.
Do you know where I could find the connector alone without the whole assy (not that it's very expensive either, but it's a bit of a waste to purchase the assy for just that little piece of plastic)? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #623080 10th May 2017 8:54am
Martin
Site Admin
IGM500011 is the difflock switch, despite what the parts catalogue and online suppliers state.
IGM100000 is the high/low switch. Way more expensive!
It's a Sumitomo HW090 series connector which may help you track it down.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #623093 10th May 2017 11:21am
o4dn
Thanks Martin! Thumbs Up “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #623112 10th May 2017 12:37pm
o4dn
From the look of it, it looks like the 3-way variant (3P090WP-HW) from this page:
http://www.easternbeaver.com/Main/Elec__Pr.../smhw.html
Am I right?
Anyone ordered from these guys before? Looks like they're from Japan. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #623127 10th May 2017 1:22pm
Naks
but why?
in low range, the throttle response is smoother so that you can have more control over the vehicle, so why would you want remove that!? Shocked --
Post #623338 11th May 2017 9:05am
o4dn
It's the opposite actually, the goal is to have the smooth throttle response on high range, fooling the ECU into thinking it's in low range even in high range. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #623345 11th May 2017 9:39am
Naks
Oh, I misunderstood, sorry.
Good luck, and let us know how it works out Thumbs Up --
Post #623346 11th May 2017 9:42am
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
I have disconnect it.
The reason is not a question of throtle response but because no power in low range.
I lose the antistal so the best will be a switch
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #623538 12th May 2017 1:52am
o4dn
Update
So I ordered the HW090 connectors, received within a couple of days (from Japan, amazing service!)
Unpacked the bits and pieces:
A high-tech electronic design: Rolling with laughter
So that I have a male and female plug that I can put between the two original connectors:
Installing the cable takes 2 minutes at most, it's very easy from under the car, so I didn't bother with running a cable back into the dash and installing a switch, partly because I'm lazy and partly because I wanted to try first and see how it affects drivability...
Took it for quick test drive, it feels different, throttle seems more responsive, as if there were fewer electronic gizmos playing behind the throttle, a bit like an old fashioned cable throttle.
Anti-stall clearly uses a different strategy and kicks in a lot earlier.
EGR is unaffected (according to the scanguage) and plays its role just as before.
I'll keep it like that for a few days to see if I like it or not... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #625425 19th May 2017 4:52pm
Remember you can disable the clutch switch too, but still keep antistall.
It'll prevent the rev overrun especially in low. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #625432 19th May 2017 5:36pm
o4dn wrote:
Anti-stall clearly uses a different strategy and kicks in a lot earlier...
Can you elaborate on this since I don't understand what you're getting at? Anti-stall only operates when there's no throttle input, how can you get "earlier" than this?
Post #625433 19th May 2017 5:36pm
o4dn
What I mean is anti-stall increase in low range, it seems it pulls harder when the ECU "believes" it's in low range. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #625437 19th May 2017 6:24pm
o4dn
By unplugging the switch, or shunting it?
I tried shunting the clutch switch some years ago, with mixed results... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #625439 19th May 2017 6:31pm
I've just used a J.P.T. Connector and a wire loop to effectively join the clutch switch wires together. To create a closed circuit. The TD5 can just be unplugged and left open. Everything the same pretty much except for revving in low range. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #625456 19th May 2017 7:17pm
