Home > In Car Electronics > Speeding fine
languedoc
Scotland 2008 Defender 110 Puma 2.4 CSW Alaska White
Speeding fine
Well, its safe to say that my speedo is way out! just received a fine for doing 79kph in a 70 zone in Carcassonne.
Someone mentioned a digital speedo that driving instructors use on the passenger side of their dash, do such things exist and are they any good?
Post #622884 9th May 2017 2:10pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Do you have an iPhone? If so, download the free app: Speed Box
The speedo in my classic is out by about 10%+, so I use the app as a check.
The other option is one of these:-
http://www.demon-tweeks.co.uk/motorsport/s...peedometer
I've looked at one of these as the other option - they are battery operated, so no wiring needed.
Post #622885 9th May 2017 2:13pm
bankz5152
Got a Satnav? Leave it on the dash.
Or depending on the model of landy you have Ashcroft do a speedo fixer
Post #622889 9th May 2017 2:24pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Just change the speedo gear in your transfer box, takes around 30 mins at the most and they're not expensive, even for genuine new ones. Remove the speedo cable from the drive, together with the clip and bolt, pull the old drive out, push the new one in and refit the cable.
If it's not been done before it can sometimes be a pain to get the old one out if it's seized in but most of them pop out pretty easily. http://www.yorkshireoffroadclub.net/
Post #622890 9th May 2017 2:27pm
ericvv
Strange. By law speedos have to be calibrated slightly optimistic. So when it shows 70 kph, you really should be going at approx 68 kph only. Mine is like that.
Maybe you just have been speeding a bit? Or do you have bigger tires on your rims?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #622892 9th May 2017 2:30pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
My Pioneer head unit has built in SatNav and GPS with visual and audible speed warnings. The woman's voice does sound very scolding though Rolling with laughter its enough to make me slow down. Its adjustable so you can set it to the speed limit +/- 0% in town and +/- 20% in the countryside etc. Its very useful. It also has speed camera warnings as a paid optional extra but I'm not sure if it works in France because its illegal.
Post #622894 9th May 2017 2:35pm
bankz5152
Eric
Doesnt mean much to Defenders when the tyres, wheels, gearboxes, tx boxes, diffs are changed so frequently.
My 90 was about 15% out, my 110 was under reading by about 5 - 6mph until I fitted much bigger tyres now it is literally bang on.
Post #622898 9th May 2017 2:40pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Puma ECU has 3 different settings for tyres to adjust the odometer/speedo, 235/85R16, 7.50R16 and 205/80 R16.
If set to the latter, the speedo is approx 10% off, which might explain why you got a fine Whistle
You should try to connect a Nanocom and make sure the the tyre size is set to 235/85R16. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #622901 9th May 2017 2:49pm
languedoc
Still on original steel rims until I decide what to change them to. I will tackle the gear at the weekend because I know that road and I was sitting at 70 on the dial. Mine is only in kms, doesn't show mph at all and comes from Spain as an ex hydro electric works fleet.
Mostly run on dirt tracks so the dust everywhere was biblical!
I dont have satnav and use a windows phone so apps are few and far between. I prefer to keep it as clear as possible on the dash except for my new parrot kit. We tend to leave cars open here and both neighbours have td5 90s whose keys have never left the ignition!
Our local, and I mean 30kms away, police station is closing because nobody needs them.
Post #622904 9th May 2017 3:07pm
Mr Fox
Sounds like your best bet is one of these then:-
You can find them on eBay as well.
Or follow O4DN's route and get the ECU reprogrammed.
Post #622907 9th May 2017 3:14pm
Riverboy
Don't they spray paint the cameras over your way? They do here 👍 Within a day of them cleaning it, it's sprayed again.
Post #622908 9th May 2017 3:15pm
o4dn
Oh, no need to get it "reprogrammed", it's merely a setting in the existing ECU, a 5 second job with a Nanocom...
Edit: I could check the setting for you if you were to come near Toulouse, but I guess you have other people with a Nanocom willing to help closer to you... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #622910 9th May 2017 3:17pm
ericvv
My Garmin adjusts the speed camera warnings to comply with the law of each country I'm driving in.
In Switzerland it will show no warning as illegal, period. No wording at all is acceptable here. Not surprised about that.
In Belgium it will clearly say "speed camera warning at xxx distance" as it is legal to do so apparently.
In France it will say "zone dangereuse sur xxx mtres". Not mentioning speed camera by name gets you away with the law there apparently. Why am I not surprised? Laughing
Post #622912 9th May 2017 3:20pm
languedoc
Im going to stick to driving the series 3 because I'm pretty sure it cant get to 70kph anyway. Or at least I don't have the onions to try!
Post #622913 9th May 2017 3:20pm
Stacey007
I use my Ultra guage as the speedo, I can see it easier than the actuak speedo
Post #622915 9th May 2017 3:22pm
