Home > Puma (Tdci) > Puma Viscous Fan Part Number
nickhodgson
Hi
What is the correct part number for a 2011 2.4 Puma Viscous Fan? PGG500340 or LR029997.
Thanks 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #622824 9th May 2017 10:01am
Martin
Site Admin
PGG500340 is Td5 and 2.4 Puma
LR029997 is 2.2 Puma
The 2.2 fan has a longer boss (the hex bit)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #622827 9th May 2017 10:20am
nickhodgson
Thanks for that Martin.
So does the 2.2 Fan fit on the 2.4 and provide the same solution as fitting a spacer to the 2.4 Fan? 1995 300tdi Defender 90 P/UP
Post #622828 9th May 2017 10:27am
dgardel
Italy
As per Martin infos
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #622887 9th May 2017 2:14pm
