![]() | Home > In Car Electronics > Aerial amp? |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21042
Yes, you can buy inline aftermarket ones 👍🏻 ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618
Yes you can but I could do with direct experience as some of them are phoney. V8 90...WIP
Sometimes OE manufacturers sell them. But not all, which is quite annoying!
The standard aerial does indeed have poor reception. Perhaps to save your time and effort it'd be worthwhile to swap to a flexj type like Brendan sells? Or at least consider, then it is fit and forget. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 7th May 2017 7:04pm. Edited 1 time in total |
| meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548
Any further info for the flexible one Brenden sells? My 90 Project : http://www.defender2.net/forum/topic52774.html
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
http://www.4x4overlander.com/product/hirsc...-defender/
It also comes with an earthing cable. |
That was the one I was thinking of.
Perfect!! Exactly what I've been looking for / imagining! Thank you Sir |
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1325
The Herschman aerial is not amplified.
To get amplified you can: 1) Get a cheap one circa £11 on ebay - some on here have had success with them 2) Get a Blaupunkt Autoflex aerial 3) Add an external amplifier e.g. this kit https://www.quasarelectronics.co.uk/Item/v...lifier-kit However, you may find that your issues are due to USB interference rather than signal strength |
Kmac- any ideas on a source for the Blaupunkt ? My 90 Project : http://www.defender2.net/forum/topic52774.html
you're right it's not amplified, however it is very well screened, and the earth lead allows you to earth the areal right back to the earth stud on the bulk head rather than a poorly earthed wing. As you've mentioned it could be interference rather than a weak signal, and just fitting an amplifier will just amplify the interference too. It's why most factory fit signal amplifers are right at the base of the aerial, so they pick up the cleanest signal to start with. |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
I converted mine so that it uses the CB aerial though a passive converter. Job done. And I now don't have the old aerial in my line of sight all the time. Got the box from 4x4 com:
http://www.4x4cb.com/public/item.cfm?itemID=829 Works a treat. Merlin |
I got mine from here I think, but it was some time ago http://www.blaupunktdirect.co.uk/antennas-...erial.html These guys also do them http://www.classiccarstereo.co.uk/antennas-aerials/ |
thank you! My 90 Project : http://www.defender2.net/forum/topic52774.html
| All times are GMT |
