![]() | Home > Td5 > Odd speedo response |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Mine does this VERY occasionally (maybe twice in the last 3 years) It hasn't happened for a while though. I can only think that it is either a very intermittent earth fault or just where the transducer is stopped in a certain position and the electrical interference on start-up generates a pulse that makes the speedo jump. Mine went to about 70mph and stayed there for a couple of seconds
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 ![]() ![]() ![]() |
Thanks for the reply Grafty99.
Presume then its just a blip in the electronics. Edward |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
I've noticed mines doing this once in the last two years, nothing has come of it so I suppose it was just an electronics glitch.
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
Usually happens when starting on a low battery.
Also sometimes you will notice the fuel gauge go to empty. Signifies your battery or grounding has issues. The defender has migrated, leaving the owner behind. |
