Home > Maintenance & Modifications > BAS Remap evolution (NO EGR) upgrade
dgardel
Italy
Yesterday "night" I tested the new version of Pete Remap (Bell Auto Services) with software EGR blank.
Pete has centered the GOAL!!!
My car was a car with the (in)famous flat spots between 2200 - 3000 rpm; NOW ARE COMPLETELY GONE!
The engine run like a dream, very quick to "take" RPM and a lot of pull, underlined "a lot".
EGR is ALWAYS CLOSED, it stay at 16-18% ONLY AT IDLE, but when I "touch" the throttle it go to 0% always.
BRAVO PETE, good job!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #62191 4th Mar 2011 8:52am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Yep .. had mine done last Saturday by Ian [IRB] Sent the mapping to Pete for a re-write and loaded it back on ecu.
What a difference!, No more flat spots, takes off even quicker than before ..... and checked my mpg at fill up , now 2 mpg better!!
Impressed bunny here - get yours done lads and lasses, you will not regret it Cool
Post #62201 4th Mar 2011 9:16am
bell-auto-services
Your welcome
More updates are in the pipeline for all bas users once made, so all please dont bombard me yet lol ive not finished the developement.
Ive a few nice adjustments like "bucket Size" changes, "DTC fault" adjustements and "Exhaust back pressure" calibrations "Turbo spool times" allong with "Air flow calculations and calibration" etc etc i want and need to do before im totally happy with the new lastes updates LR software so bare with me Smile
Thats of course if Landrover dont let out yet another software update and i have to start again lol.
The files i sat down last night and emailed to various users were a string of many updates im working on as we speak and as said more will come soon.
Pete
Post #62217 4th Mar 2011 11:41am
dgardel
Italy
Thumbs Up Thumbs Up Bow down Bow down Bow down Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #62218 4th Mar 2011 12:12pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi Pete
forgive my ignorance but can I have just the 'EGR close' patch added to my ecu or do I need to buy the remap interface equipment as well ... I dont want to tune the motor just bypass the EGR.. Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #62228 4th Mar 2011 2:13pm
bell-auto-services
wyvern wrote:
Hi Pete
Hi
Yes you could, but i would need the car here to apply it or you would need a bas interface to apply it your self.
Pete
Post #62230 4th Mar 2011 2:19pm
Naks
Dgardel, you are so right, this is what the standard Puma map should have been like! I loaded my BAS remap last night, and this morning I had to go to the suspension specialist, 70km away. I kept looking for a 7th gear on the highway! Thumbs Up
As Pete promised, this is what I wanted - smoother, more linear power delivery, and of course the EGR self-cleaning does not happen. All the way there & back (140km highway driving) it felt livelier, but not so much that even an LR mechanic would notice the difference, or if he did, would put it down to tyres, fuel, etc. My landy is bog standard, but am thinking of putting a bigger intercooler at some point.
One thing that worries me though, between 1800-2100rpm the engine clatters a lot, as if there were a bunch of nails rattling around in there. I noticed this in all gears at this specific rev range - is that normal? --
Post #63881 16th Mar 2011 10:37am
bell-auto-services
The ECU on the puma engine is fully adaptive, it will take some miles to settle down fully. Though the engine will also sound different when tuned in most cases as we are working the injectors and other components harder than in original tune.
Though i cant say ive ever heard a "Nails" type noise.
Pete
Post #63882 16th Mar 2011 10:43am
Naks
bell-auto-services wrote:
The ECU on the puma engine is fully adaptive, it will take some miles to settle down fully. Though the engine will also sound different when tuned in most cases as we are working the injectors and other components harder than in original tune. Though i cant say ive ever heard a "Nails" type noise.
Thank Pete!
I think the Tdi & Td5 noises were more tractor-like, the Puma on the other hand is too refined, hence nails Rolling with laughter --
Post #63884 16th Mar 2011 10:54am
bell-auto-services
Your welcome.
Pete
Post #63885 16th Mar 2011 10:56am
bell-auto-services
Ive just been out in a standard 90 to put some fuel in for when the customer collects it and listend for the "nails" i did here what i think you are explaining and its a normal noise from a puma even standard.
Pete
Post #63897 16th Mar 2011 12:09pm
Naks
Yep, it just does it a bit more with the remap. My Puma did not really have this noise until the engine started loosening up at around the 10000km mark. --
Post #63898 16th Mar 2011 12:15pm
Naks
Btw, with retards to the ECU adapting to the new map, how long does this take? This morning I did 140km, and we are going away this weekend, will probably do another 400km. --
Post #63926 16th Mar 2011 3:07pm
bell-auto-services
It should have done what it needed by then easly.
Pete
Post #63934 16th Mar 2011 4:12pm
Naks
Something else I am noticing, although I must monitor further, the EGT is coming down much more quickly after I have stopped.
Usually when I get to work (0830) I have to wait 2-3min for the EGT to come down to 160C, but this morning (1100) it was already down to 170C by the time I had parked. Similar thing just now when I got home. --
Post #63949 16th Mar 2011 5:29pm
