![]() | Home > Camping, Caravanning and Holidays > Alko tow ball... Oh and 13 pin electrics |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141 ![]() ![]() ![]() |
Alko hitches have a longer neck than standard Tow Balls and will be no problem fitted to a 110. However never get any grease on the Alko tow ball if an Alko hitch is fitted to the caravan otherwise you will ruin the stabiliser parts fitted inside the hitch head.
Nothing wrong with 7 pin to 13 pin adaptors they work really well and are the easiest and less costly option. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
JustFX Member Since: 10 Nov 2016 Location: Mendip Hills Posts: 190 ![]() ![]() ![]() |
seeing as they sell Dixion Bate stuff on their own website I would take it that standard ones are ok
http://www.al-ko.com/shop/uk_vt/products/t...pment.html Though reading their own FAQ you need to have a clean (no grease), unpainted ball. It depending on how well used your current one is it maybe worth replacing to be safe. ![]() |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
There's no reason why you couldn't run both although the adaptors are pretty good, especially the all in one versions rather than the fly lead versions. Your best bet is to convert to 13 pin on the vehicle though as it's a MUCH more secure fitting and less prone to corrosion issues. You can run 13 pin with the same wires as a 7 pin if you don't want to run the extra wires for fridge, charging and so on. I've just finished converting all 4 of my vehicles to 13 pin sockets and still tow the occasional 7 pin trailer or caravan. I've converted my own trailers to 13 pin too. http://www.yorkshireoffroadclub.net/ |
A standard Towball will not fit a Alko hitch head the Alko hitch requires a longer knecked ball . Though an Alko ball will fit all hitch heads. ![]() ![]() http://www.youtube.com/user/conwy1 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18026 ![]() ![]() ![]() |
That'll be because Al-Ko not long ago took over Bradley/Dixon Bate. |
Paulv8 Member Since: 09 Jun 2013 Location: Milton Keynes Posts: 618 ![]() ![]() |
thanks guys! V8 90...WIP
Sammyboy Member Since: 28 Feb 2017 Location: Hampshire Posts: 121 ![]() ![]() ![]() |
Hi Paul
When you buy a new ALKO towball it might be supplied painted black. It is advisable to remove the black paint from the ball with either fine wet and dry or paint remover before use as the paint will clog up the surface of the small brake pads inside your caravans tow-hitch. This will ruin the effectiveness of the stabilisation effects of the hitch. Discovery 4 HSE Defender 2.2 110 USW XS Ford Kuga AWD Discovery 3 Range Rover P38 Discovery - 300 TDI Discovery - 200TDI |
Rallymental Member Since: 17 Aug 2015 Location: The Garden of England Posts: 468 ![]() ![]() ![]() |
I've towed for years in 'normal' cars without using the alko ball, however when you tow with the defender you'll probably be using an adjustable plate. It's this plate that causes the problem, if you use a standard ball, when you turn a corner you will rip the alko stabiliser head apart as it's too close to the plate. You can pick up an alko "type" ball through one of the eBay company's, I just got a new one for £14.50 inc postage. It's exactly the same as the alko proper.
No problem in using an adaptor for trailer use it's a single piece so no dramas. If it's the other way round; 13 pin on caravan and separates on car then it's a nightmare as the adaptor is a big bulky thing with 3 socket/plugs on. The definition of insanity is doing the same thing over and over again but expecting different results. Solihull, 1948 - "If we paint the chassis, it will last for years" Solihull, 2015 - "If we paint the chassis............................. |
