![]() | Home > Td5 > Clutch or turbo problem? |
| roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039
If your clutch is gone the engine wil rev and you don't really get more speed. Best to try in 4th gear start at about 1500 rpm and with full throttle somewhere just above 200 rpm your revs will go up more quickly then your speed. If that happens your clutch is on the way out.
The symptoms you mentione sound to me something engine, turbo or sensor related. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802
Sounds like either a failed map sensor or if you have a dual channel limit box on the ecu (when stage 2 tuned) then that could have failed. 2002 90 Td5 Station Wagon
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
You may have a split in the pressurised turbo hoses. Sometimes they are barely visible and can hold pressure intimitently depending on conditions, heat etc. It's not common for MAF or MAP's to completely fail other than just being dirty. If this is the case there should be DTC's logged but not always. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Even with a split hose however you would see some turbo pressure and almost definitely hear it. Try removing and cleaning the MAP sensor to see if that changes anything
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692
Check MAP sensor - normally it should show some pressure in live data on Nanocom - nearly the same as ambient pressure (approx. 100 kPa) , and with slight increase (approx. 150 kPa in standard car) after good short revving the engine in not moving car. Simultaneously, the ambient pressure should drop a bit (from 100 kPa to 98 kPa). "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
| TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88
As above, MAP sensor most likely culprit.
| huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379
Thanks guys, I have a new MAP sensor coming. Fingers crossed it's that
Here are a few lines from my log on the drive in for reference; Click image to enlarge TD5 Defender 90 Discovery 3 HSE |
Turbo Pressure 0 in table - this is MAP and is not good. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Replaced the MAP, goes like poop off a shovel!
So, it was the MAP! Thank you all for your input TD5 Defender 90 Discovery 3 HSE |
Great news, the MAP does have a great deal of difference on performance.
Did you go Genuine or OEM? ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I figured like the MAF, genuine would be best
It actually goes a bit quicker than after remapped so maybe it's been on the way out for a while... Could the remap (extra heat) possibly have caused it? Thank for your help TD5 Defender 90 Discovery 3 HSE |
After all this, I've now tapped my manifold and fitted a boost gauge
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
I assume you have used Nanocom to record the data to an SD card?
Is turbo pressure the same as the map reading? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Didn't have the nanocom with me today but have already got it out for tomorrow. Will let you know... TD5 Defender 90
Discovery 3 HSE |
| All times are GMT |
