Home > Maintenance & Modifications > RDX K Switch for rear wiper
Mr Green
United Kingdom 1991 Defender 90 200 Tdi SW Corris Grey
Just bought an RDX K Switch to replace the fitted LR rear wiper one. Trouble is the one that came from Bolt on Bits seems to be a straight on-off type, though specified for the job on eBay! Looking at the electrical diagram it would seem that it needs to be a 2 way switch, I think. Has anyone had this issue and managed to overcome it? Thanks in advance.
Post #621667 4th May 2017 5:48pm
mk1collector
My rear wiper switch is straight on off but is a factory one not rdx Ray
My build thread
Post #621669 4th May 2017 5:51pm
mk1collector
I think I've only ever used it once Rolling with laughter Ray
My build thread
Post #621670 4th May 2017 5:52pm
gilarion
They are all on off you can if required fit a mod that will give you intermittent functions.
Tells you how here
http://www.defender2.net/forum/topic1810.h...p;start=30 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #621671 4th May 2017 5:54pm
Martin
Site Admin
A 1991 Tdi has a combined wipe (latching turn) and wash (momentary push) switch. I guess the RDX switch is for Td5 2002MY and later, when they split to two separate square switches?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #621682 4th May 2017 6:19pm
Martin
Site Admin
Found the switch on eBay and from the description of the terminals it is simply power in -> power out with illumination.
So at the very least you would need a 5 pin relay to make the rear wiper work. Plus you would have to wire it so it does both the wipe and wash at the same time, you would lose the option to have one or the other.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #621685 4th May 2017 6:28pm
Mr Green
Thanks for the help, didn't want to go down the relay route if possible.For info I'd already separated the washer circuit out with a momentary Carling switch. I suppose I could always discard the stop circuit wiring and put a direct feed to the motor?
Post #621722 4th May 2017 8:31pm
Martin
Site Admin
The relay is the only way to get the parking function for the wiper.
So yes if you are happy to have no parking then you can wire direct.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #621724 4th May 2017 8:32pm
Mr Green
Thanks Martin. I'll give both methods a go and let the group knwo how I got on.
Post #621735 4th May 2017 8:45pm
Mr Green
Hi All, I've just had a look at my wiring at the rear wiper end and noticed that I have four wires coming from the wiper switch and the wiper only has 3 wires coming out of it a RLG and a NLG, and an earth. No solid green.
As I've changed the rear door as part of my upgrade project and the original wiring was ripped out, without me making a note of it, duh! has anyone come across this wiring combination before and if so what was the work around? Would like to get it working properly if possible.
Any help much appreciated.
Post #621877 5th May 2017 11:54am
