![]() | Home > Tdi > 200Tdi Race engine - Weak points and limitations |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
Very thin on the ground in the UK im afraid, the expense of the drive train would be pretty severe too 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
Boost Member Since: 17 Oct 2014 Location: Gloucestershire Posts: 203 ![]() ![]() ![]() |
Finally fixed the oil leak problems. The 200tdi's boosting at 25psi max. Definitely needs that 1.2 ratio transfer box upgrade now as it's still got a 1.6 in and maxes out rpm wise at about 55mph, and you can't get through the gears fast enough
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313 ![]() ![]() ![]() |
Sounding good boost!!
She must get off the line like a rocket with a 1:1.6 ![]() |
1st gear's pretty redundant at this point!
![]() Seriously though on skinny road tyres a 1.6 box with a 200tdi (originally 2.5NA) is laughable. Got a 1.2 box waiting with new input gear from Ashcroft fitted, awaiting the grungy rust-coloured sludge and worn input shaft when we take off the 1.6 box though ![]() ![]() ![]() |
Stumpy R380s are pretty hard to come by which is why they command a high price. Best to buy a td5 box and convert it yourself. That's what I have done.
http://www.ashcroft-transmissions.co.uk/in...p;catId=99 1993 200 Tdi 90 CSW
Thanks guys will definitely look into this when I've got the time, presume there's guides and stuff.
Might get the old girl on the dyno this week ![]() |
A quick update vid
![]() Sorry have been a bit busy will message people soon! Cheers ![]() |
Great vid as normal
![]() ![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11015 ![]() ![]() |
Great video both of you
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3796 ![]() ![]() ![]() |
G'Day Boost, great video.
So the performance is all you expected it would be?,....where is the main difference? Good job, Pickles. |
Hi guys thanks again for all the feedback, always ace to see what people think
![]() Pickles we're going to make a vid comparing mine to Rich's standard tdi at some point with a bit of racing and maybe a dyno run Any suggestions will be gratefully received, we're trying to make stuff that people want to watch in our spare time really so let us know! ![]() Cheers guys |
Any update?
The videos keep getting better btw, great watch ![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 844 ![]() ![]() ![]() |
Yeah, come on lad's it's about time we had another video
