Home > Maintenance & Modifications > Nakatenanga cargo track fitting ideas
Devon-Rover
Just mulling a few ideas around in my head, as I don't want to drill any holes in my beloved defender.
Has anyone used the Nakatenanga cargo track and mounted it using the existing holes in the tub that have the lashing rings. Instead of simply mounting on the floor like I have seen many, If I mount along the sides this still leaves a flat floor and the bonus of no holes drilled.
The measurements look promising with the profile looking like the it'll sit on the side and line up. The lashing eye bolt centre is circa 20mm from the floor and the cargo track is 50mm wide, so maybe only minor trimming of the lower edge but not enough to affect operation.
Anyone??
Post #620960 2nd May 2017 9:43am
josefk
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
hi devon-rover,
not nak cargo track and not bottom lashing ring holes but ... FWIW I've put front runner cargo rack (is black - looks OEM)on the side of the wheel arch where a seat would be bolted through in a 90 SW (I permanently have one seat out) - that means its a few cm up from the floor...
it works well to secure boxes, bags and occasionally a fridge into the side of the load area rather down into the floor of the load area...
Post #620998 2nd May 2017 12:13pm
Devon-Rover
That's good to hear. I have 3 wolfboxes plus other usual camping odds and ends and wanted the location of the lashing points flexible so I can keep it secure depending on what is carried.
Post #621017 2nd May 2017 1:35pm
Sulisuli
http://www.defender2.net/forum/topic52531....cargo+rail
This link may help. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #621059 2nd May 2017 5:09pm
miker
Just drill some holes, it's not that bad!
Post #621069 2nd May 2017 5:32pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
For months I was wondering why the back of the 110 smelt like a wet dog until I pulled the rubber mat out to find that the carpet underneath was soaking wet, tracking the damp back it appears that the standard rings are letting in water, the olny seal is the nut on the end of the stud . It looks as though Leeds is getting an order Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #621071 2nd May 2017 5:39pm
Devon-Rover
Thanks for the link simon they do look really nice bits of kit, I'm still thinking that I can mount them further down as the 110 only has 2 eyes fore and aft of the load bay and so I only need one type of load restraint so it might as well be just the cargo rail.
ARC99 I don't have carpet just rubber matt but then the rear is watertight and as precaution the securing bolts would have thread lock on them just to keep the water out and naturally another reason not to introduce more holes into the wheel arches where water could get in.
Miker With all the mods soo far I have only drilled two holes in the battery box and four in the chassis that's it. And should I need too, be able to return her to forecourt condition easily without any evidence visible.
Post #621092 2nd May 2017 7:22pm
Sulisuli
Now im tempted to do this too Very Happy just need to pluck up the courage to squeeze the trigger on the drill Whistle 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #621097 2nd May 2017 7:43pm
Devon-Rover
It is one those things that you think why didn't they do it from the factory? instead of a few flimsy rings in each corner.
Post #621130 2nd May 2017 8:45pm
Devon-Rover
FYI they doo fit. Would be mighty tight with carpet there and you have to drill the holes slightly offset but It can be fitted without trimming the tracking
 Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #705697 6th May 2018 10:03pm
leonski
I fastened ours to an 18mm birch ply shelf, one strip in the middle and one to the right, this was so we could tie down x4 wolf boxes and also get dog in the back safely.
The track is great and it worked an absolute treat!
Cheers,
Leon
Post #706748 12th May 2018 2:32pm
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Did the rails come pre-drilled for attaching to the wheel arches?
Post #706794 12th May 2018 7:55pm
Devon-Rover
No they come undrilled from Overlander 4x4. I drilled them slightly off centre to allow the rail to fit without trimming the lower edge and still use the factory holes. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #706943 13th May 2018 7:00pm
2010Blackdefender90
Thanks. Thumbs Up
Post #706958 13th May 2018 8:19pm
