Home > In Car Electronics > What lead do I need please? Std LR radio to Alpine? also Mic
Page 1 of 3 123>
Stacey007
Hello
Had a spare few mins, thought I would change the radio (stop gap until I do the double din swap)
Old Land rover Radio out and this has two leads in the back of it (in picture)
New Alpine radio only has one?
What lead do I need please to connect up?
Thumbs Up
Also where do people place the mic for talking to I put it here but not stuck it down yet...
Thanks
Post #620860 1st May 2017 8:44pm
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
I think you need an ISO connector...
Look here: http://www.defender2.net/forum/topic29061....t+2014+iso
I put the mic on the left side of the cluster, by the drivers side air vent, helps with wind noise and will also pick up a passengers voice. Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #620946 2nd May 2017 6:52am
Peaknocker
United Kingdom 2014 Defender 90 Puma 2.2 HT Fuji White
Hi,
Before you buy a new lead, follow the wires out of the back of the two Plugs in the dash you may find they are plugged into a grey plug that the alpine one will plug directly into.
Post #620983 2nd May 2017 11:08am
Stacey007
Hello
I'm a bit lost, my leads at the back do not match the radios single one, so I have tried two different ISO leads that the audio places say should fit?
16 pin in the back of alpine to the two seperate leads in my dashboard.. Neither have worked though.
Can I get a lead that goes from the Alpine lead it came with to my two leads in dash?
Not sure now what I can be doing wrong I would have thought with the correct lead its plug and play?
Thanks
My leads in dash and the loom from the back of Alpine
So I took this loom out and fitted the second of the looms I bought which split to my two leads.. still nothing
Help please.... Thumbs Up
Post #625451 19th May 2017 7:11pm
Peaknocker
Is it a puma you have?
If so follow the cables coming out of the back of the two plugs in your dash and they will plug into another connector located below the clock.
You should be able to unplug this and plug the one you have in your hand direct into this. Mike
Post #625454 19th May 2017 7:15pm
Stacey007
Hello
Ok thanks I will try this, will be over the weekend now. Thanks
Post #625455 19th May 2017 7:16pm
Stacey007
Hello
So tried again, old radio out and torch in gap and pulled leads a little in the hole. Nothing attached to the cable?
these are what comes out of the dash...with the newer ones near them in this picture
This is the back of the head unit with the 16 pin lead in
but still nothing....
so this is the second lead I have bought and seem to fit the connectors on both the radio and car but nothing from the headunit?
This is the lead next to the lead that came with the radio. Am I missing anything? I have checked the radio fuse and that appears fine.
SO old radio back in and all works again
Post #626351 23rd May 2017 4:15pm
Peaknocker
Just sent you a PM. Mike
Post #626354 23rd May 2017 4:43pm
Stacey007
^ Great to talk to you Very Happy
Will try what you said maybe tomorrow now. Thanks
Post #626417 23rd May 2017 8:05pm
Stacey007
Hello
OK so I tried Chasing the lead back removing the front part of dashboard in the hope I would find a bigger lead connect to the two smaller ones... But no luck.
Has anyone else fitted this radio to a puma? which has the std Radio its a XS model?
If so what lead did you require.
The radio shops are saying its this one and I've tried two now and no luck?
Thanks
Post #626840 25th May 2017 2:51pm
Martin
Site Admin
Which leads have you been sold (part numbers/IDs)?
Any chance of a detailed photo of the wires coming out of each Alpine connector? On the original LR loom (cloth taped one) and a lead you've been sold?
A standard ISO -> Alpine should work Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #626842 25th May 2017 3:05pm
zsd-puma
Have you actually got power both, permanent live, and ignition live coming through to the ISO connectors coming out of the loom?
Post #626868 25th May 2017 6:42pm
Stacey007
^ I will try and get pictures that make sense.
As for power the original loom works fine with my original land-rover cd player.
I've not tried a multi-meter on the 2 other looms I have tried, One I sent back as thought its not working but then the second isn't...
This is the lead which came with head unit.
but these are the leads in my dashboard (the two at the back)
This is the back of the head unit with the 1st lead I sent back...
This is the lead I have currently and plugs into back of head unit and the two leads coming out of dashboard fine, I was told the extra lead is for a phone. but plugging this in nothing happens?
Post #626871 25th May 2017 7:03pm
zsd-puma
extra lead will be a remote control cable for a phone, power antenna, external amplifer etc. If you're not using it just tape it up.
Does the new head unit actually work? Because if you've got power where it should be then the head unit is likely faulty. Just because it's new doesn't mean it's not faulty.
You say you've checked the radio fuse, i assume that's the one in the fuse box? (which must be fine if your original radio still works) What about the small one in the back of the head unit? Even if it looks ok, try replacing the fuse anyway, i've had a blade fuse once in the past that looked fine, and had a continuity test passed on a multi meter but just wouldnt work.
Post #626880 25th May 2017 7:35pm
Stacey007
Hello I bought it off a forum member here who upgraded to double din and yes I have a guarantee it works?
I've checked the fuses and they all appear ok and as you say the original radio works..
Thought it would be plug and play nice quick job.
Confused
Post #626892 25th May 2017 8:55pm
Page 1 of 3 123>
