Home > Technical > Smallest LT230 handbrake drum
taazzukcb
United Kingdom 2004 Defender 110 Td5 DCPU Stornoway Grey
Long story short,
I need to make my handbrake drum smaller on the transfer box. It's on a Defender 110.
Standard drum is to big full stop. Disco V8 box one is less bulky and just fits however rubs on chassis.
Is there smaller / thinner at all?
Raptor 4x4 seem to have an image of a drum with a chambered front edge. What are these from?
Might be an option if smaller!?
Cheers all.
Post #620809 1st May 2017 6:41pm
taazzukcb
Also,
I am considering shaving with a grinding disc.
Are the drums liable to shatter with a bit of work applied to them?
Post #620810 1st May 2017 6:43pm
ickle
Disc brake conversion? Not cheap but meant to be A1
Post #620818 1st May 2017 7:06pm
taazzukcb
I have considered but it mounts to the same point. What diameter are they compared?
Can the callipers be mounted elsewhere as the drum is right up to the rear foot well box, too mount callipers won't fit at all.
A bit spendy at the mo too!
Post #620836 1st May 2017 7:42pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
I can't think of any reason why the transmission drum brake would rub on the chassis if it's installed properly ??? What have you modified to make it rub ?
As others have said though, a disk brake conversion is a lot smaller than a drum, the calliper normally mounts at the top. http://www.yorkshireoffroadclub.net/
Post #620856 1st May 2017 8:34pm
Mo Murphy
Indeed, I can't imagine why it would rub on the chassis !
50 Shades of Pennine Grey
Post #620877 1st May 2017 9:04pm
I'm off this week, if you need to look at an x-eng handbrake? I put one on the 90.
Why won't it fit? His 110 isn't exactly standard. Cool Cool
Post #620889 1st May 2017 9:33pm
Devon-Rover
Rakeway engineering do their own cable disc handbrake to fit on the back of the LT230 coupled with their own short output adaptor. I cannot find a picture but having seen one it is fairly compact. I would drop them an email.
Post #620918 1st May 2017 10:54pm
taazzukcb
Erm yes, it's not what we call an original spec Land Rover Smile.
I'll give Neale a bell later, see if he may be able to skim some meat off the drum. He's done plenty of small bits for this over the past couple years.
I have considered the shorter output housings, both Syncros and Rakeway. But trying to avoid the cost. Would mean yet another custom rear prop too!
Rakeway is 70mm shorter I beleive, Syncros is 65mm.
Both however do away with the speedo drive, which I have now modified to supply my dials.
If not, I may just prop the 2 left wheels up and lye underneath with a grinding disc :p! With someone sat near the brakes for my H&S fulfilment Laughing.
Greeni, cheers for the offer dude! I have so many reasons I need to pop to see you! Lack of time atm is my biggest downfall with everything! Hency why everything is taking so long!
Post #620977 2nd May 2017 10:58am
taazzukcb
Spot some of the differences.
Post #620979 2nd May 2017 11:02am
taazzukcb
Few More :p!
Post #620982 2nd May 2017 11:06am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Not sure of the legalities surrounding it but could you remove the conventional handbrake altogether and use a hydraulic system that locks the normal brakes?
Is that an OM606 by the way?
Post #620989 2nd May 2017 11:26am
taazzukcb
There's 1 or 2 legal hydraulic systems. Again, looked into it, but it's trying to keep everything a little sensible now :p!
Several mechanical systems too, plenty in fact.
But just want it back on the road now. Stuff like that can come down the line. Don't "need" it in an Auto really, just for MOT and to stop defending me from screeching on the chassis and reducing vibration when running.
Post #620990 2nd May 2017 11:41am
taazzukcb
Yes, a 606 too Smile.
Ex. TD5.
Post #620991 2nd May 2017 11:42am
Move the crossmember?
Post #621001 2nd May 2017 12:24pm
