Home > Technical > Bulkhead hole - how bad is this?
24heuer
Scotland 2010 Defender 110 Puma 2.4 CSW Keswick Green
Hi,
Under the bonnet tinkering and noticed a hole about 4 or so inches long between the brake servo and the RHS wing. Big Cry
Sure it wasn't there last time i looked Confused
Anyway, had a good poke round and couldn't find anything else - bulkhead corners above/below the door hinges etc. look fine.
The black piece you can see behind the hole is the folded steel trim below the dashboard, above the pedals.
So, is this a common place to find rust?
I can't remember seeing it here on my last Defender which seemed to rust from the door pillars inward.
Guessing it needs addressed asap - anyone got any advice or tips on how to repair with minimum disruption?
Many thanks,
Andy...
 Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #620829 1st May 2017 7:28pm
Mdm
i would be taking the dash out or well apart for access
wing off for more room to repair
buy a quality repair panel and use what you need from it or if you can fabricate make your own
Post #620833 1st May 2017 7:39pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
MOT failure, needs correct repair will be corrosion inside bulkhead
Post #620922 1st May 2017 11:03pm
24heuer
MOT issues due to proximity to brake servo?
Ok, not an easy fix then.
Minimum I guess is - wing off, brake and clutch pedal boxes removed, air filter and all that gubbings etc. out the way, dashboard out....
This is growing arms and legs Big Cry Big Cry Big Cry
I can see it's at the top of a join or seam so I'm guessing the rust is through to both layers.
Without removing more bits I can't see any more rust but that's not to say it isn't there (it was only when I was moving cables out the way I spotted this and it's well hidden from view inside the vehicle).
Given the amount of work to remove all of the above and then do a repair, and, still not be 100% comfortable that it's all gone, what are thoughts about swapping the bulkhead out for a galvanised one instead?
It's a '95 110 300Tdi with a galvanised chassis, side frames and body cappings already. Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #620950 2nd May 2017 7:52am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
From my experience you'll have the same all the way across the bulkhead in patches.... Land Rover stopped using joint sealant to save costs.....
I'd check the top edge of the bulkhead under the screen (under the rubber seal) as I suspect it has holes in it and that's how the water is getting in there. V8 90...WIP
Post #620962 2nd May 2017 9:53am
VVS210
It looks to me like a replacement bulkhead job anyway so as you've already got a galv chassis and cappings I'd do the galv bulkhead too.
Bought my 2002 DCPU with one eye on replacing both chassis and bulkhead with galv items in a few years time to make it a 'keeper'.
Thumbs Up
Post #620964 2nd May 2017 10:09am
24heuer
Thanks.
Still amazes me how a simple task like checking the clutch fluid can develop into a fully blown bulkhead swap Shocked
Guess that's Land Rovers for you Laughing Cheers,
Andy...
Edinburgh, Scotland
http://24heuer.com
Post #620975 2nd May 2017 10:49am
