Home > Wheels & Tyres > Rotating 235/85/16 GOODYEAR WRANGLER MT/Rs
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Hi all,
Hope everyone is well and enjoying the long weekend.
My 110 is running 235/85/16 GOODYEAR WRANGLER MT/Rs. Noticed the area behind the spare wheel never gets a clean so I took the spare wheel off this morning, before I put it back on, appreciate thoughts on how best to rotate the tyres so they all get even use as I'd rather have 5 evenly used tyres than 4 really used tyres & 1 aged but 'unused' spare.
1) Looked online and understand that the 235/85/16 GOODYEAR WRANGLER MT/Rs are not directional, can someone here confirm please?
2) I would like to rotate the tyres and include the spare in the rotation, appreciate thoughts on how this should be done. e.g. should I exchange diagonally RF to LR, LF to RR & RR to spare? OR swap back with fronts & pick a random swap with the spare? OR just rotate round-robin and pick a random one to swap with spare?
3) How often should I rotate the tyres? I was thinking every 10k to keep the wear even.
The vehicle has done 8K miles and I expect to do around 12k miles per year. Apart from the occasional greenlaning day trip with Collin Bell a couple of times a year, its mostly motorway running.
Many thanks in advance for your advice.
Best, APK
Post #620422 29th Apr 2017 8:17pm
JOW240725
Watching with interest, something I've been thinking of doing. James
Instagram @suffolk_rovers
Post #620431 29th Apr 2017 8:52pm
Siwynne
They are not directional I've just had two turned on the rims so they wear evenly after a tracking issue was resolved. Check for tread blocks becoming cracked on the old inside edge.
Post #620447 29th Apr 2017 9:51pm
I swap FNS with ROS and FOS with RNS every 6 months (15 thousand miles) or so. I don't bother with the spare though, just the four on the ground.
I run KM2s and find that this keeps the tread blocks even.
Post #620453 29th Apr 2017 10:44pm
Won't you need a set of four axle stands to do that? I was going to until I had this tyre cut issue. I don't think there is a need to excessively swap around but saying that I only do about 8k miles a year though. As usual B-W's advice in my opinion sounds around spot on to me. Reminds me I need another pair of Sealy axle stands 👍🏻 ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #620457 29th Apr 2017 11:07pm
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
I've never rotated my km2s and find they wear pretty equally. 20k miles on them. When I buy a new set, I'll swap the spare onto the truck. 2009 2.4TDCi XS Utility Wagon.
Post #620459 29th Apr 2017 11:16pm
ibexman
I wish I had the time to worry about things like that Rolling with laughter
Post #620461 30th Apr 2017 12:09am
Retroanaconda
Indeed, no point on a permanent 4x4.
The fronts will wear slightly faster but it depends on your driving style.
Post #620498 30th Apr 2017 10:13am
APK
Thanks Siwynne, will do Thumbs Up
Post #620720 1st May 2017 11:37am
APK
Thanks blackwolf Thumbs Up
Will do the same then, but will swap in the spare so they all get an even run as I plan to upgrade to the KM2s at a later date.
Any idea how long the MT/Rs will last in terms of mileage & age?
Post #620721 1st May 2017 11:42am
APK
Hey custom90steve, thanks for your comment.
I'll probably ask for a favour at the LR dealership when I get STC50301 fitted Very Happy
Post #620722 1st May 2017 11:46am
APK
Thanks for your comment ChrisWoods
I plan to change to the KM2s when I'm done with these so I won't be able to swap the spare in.
Post #620723 1st May 2017 11:50am
APK
Thanks Retroanaconda, will compare the wear between them at 15k; may expose any alignment issues.
Post #620724 1st May 2017 11:52am
Siwynne
In terms of mileage and age I am on the original set at 4 years and 48000. Due to change when I rustle up the time effort and cash. Rears will probably do anther 10000 but fronts are definitely due because of worn edges. All four will be replaced at the same time. One new one will go as the spare and the unused spare will be a road wheel.
Post #620728 1st May 2017 12:26pm
To address a few of the points raised above:-
- When I swap mine round I use a couple of spare wheels from my spares mountain to avoid the need for multiple jacks or axle stands.
- I have managed to get 100,000 miles out of one set of BFG Muds (original pattern, not KM2) on my Disco 2. KM2s wear slightly quicker and I generally find that replacing them at around 65k miles means they still have enough tread to be effective and to be saleable.
- I find on both the Disco and Defender that front and rear tyres wear at the same rate, however the wear characteristics are dependent on rotation direction because the leading edge of a tread block will always wear quicker than the trailing edge for fairly obvious reasons, which has a significant effect on traction and braking. The main reason I swap them round is to even out this directional wear.
- If you drive for prolonged periods at high speed on tarmac on mud tyres you will end up with alternate tread blocks wearing much more, for reasons I have never figured out. It is not possible to even out this wear pattern but it is possible to avoid it.
Post #620924 1st May 2017 11:22pm
