Home > Maintenance & Modifications > Full internal roll cage in a 90
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Just fitted a soft top on the tdi, the land rover use to have a rear cage which will be fitted soon, but I was thinking of a full internal. I know the Army rally team have them along with others, but was wondering if anyone has pictures showing fitment and location of the front cage, was wondering how it fits around the accelarator and if it reduces access. Will I have to move heater controls as well.
Any pictures would be appreciated.
Pete
Post #620014 27th Apr 2017 9:30pm
Harrygf
Have you considered the Safety Devices 6 point internal cage that the soft top hood can sit on?
Just did mine. Write up to follow soon.
H[/img]
Post #620105 28th Apr 2017 10:38am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
http://www.africaland.it/forum/viewtopic.php?f=10&t=103235 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #620243 28th Apr 2017 8:22pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
WTF? Shocked Thats horrible. Its like a load of old scaffolding. Why would anyone want that? Question
Post #620247 28th Apr 2017 8:39pm
agentmulder
Kuwait
^ to use as a roll cage?
(did I miss some sarcasm?) Solved the bowel problem, working on the consonants...
Post #620257 28th Apr 2017 9:09pm
Riverboy
Really? The roof caving in would be the least of your worries. Your more likely to break your neck on all that metalwork Rolling Eyes
Post #620258 28th Apr 2017 9:13pm
agentmulder
Kuwait
Ok, I see your point regarding the overhead and forehead bashers being much closer to the driver than the standard headlining, and I must admit I don't have much of a clue regarding the common specification/regulations and wisdom behind where or where not to place such parts (aside from reading the NZ road standards re. cages, which according to the SD engineers are very restrictive).
But in the absence of that I would have hope that anyone putting in the time, $$ and effort to build a cage would have thought the dang thing through to that level, like "in the event that the bad thing happens, then so and so factor will restrict further bad things, and then accordingly I can place element in question here".
BUT, yes, it takes all kinds of idiot to make the world go round and I'm reminded of the Dunning-Kruger effect:
"a cognitive bias in which low-ability individuals suffer from illusory superiority, mistakenly assessing their ability as much higher than it really is"
Shocked Laughing Solved the bowel problem, working on the consonants...
Post #620271 28th Apr 2017 10:10pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
I guess it's lucky everyone has different requirements... otherwise there could be a shortage of awful fake Recaros.
For road use I would want the front hoop to be external along with the side / roof bars.
The main hoop inside is fine when padded.
It looks very much like that image showing the full internal cage is in a competition car where harnesses and helmets would be used 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #620317 29th Apr 2017 8:57am
peterl
Thanks, looked at safety devises replacement set up, but want something more substantial direct to chassis.
Post #620659 30th Apr 2017 10:57pm
Mo Murphy
I think theatre's internal set up looks like a very tidy internal roll cage, nicely made.
Having made a cage myself once, it is a God awfully difficult job to get right. I'd go along with the comment that the front part should be external as the defender does not lend itself to a nice straight route to the chassis outrigger on the inside and of course does leave the noggin somewhat vulnerable if not wearing a helmet.
Its built to do a job, not look pretty and shiny and as such I'm sure it will excel.
50 Shades of Pennine Grey
Post #620725 1st May 2017 11:56am
Ramsay
Scotland 1995 Defender 110 300 Tdi CSW Auto Keswick Green
Unless used with multi point harness and possibly helmets I'm not sure a full internal cage really helps. You might avoid a roof collapse then still get a skull fracture from those internal tubes. 1995 Defender 110 CSW
1971 SIIA Lightweight
Post #620764 1st May 2017 3:17pm
bankz5152
Why internal? Its not a drift car and you'll loose space in an already spatially limited vehicle. Defenders actually look good with external cages so...
Post #622661 8th May 2017 2:52pm
