Home > Technical > 2.4 Puma security / cut off / immobiliser
Page 2 of 2 <12
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
Ah, I saw that!
If I try disconnecting it and cranking the engine, what should happen?
Post #620022 27th Apr 2017 9:53pm
diduan
Bulgaria
Take the ECU with you when you park Mr. Green
I went for a thick chain and a lock. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #620050 28th Apr 2017 6:49am
nitram17
X4SKP wrote:
Bigger Picture... Puma Defender (generally should be this)
Pardon my lack of sparky knowledge....do you have a legend for the diagrams such as wire size?as i can guess what the numbers and letters mean but im not sure!
Post #620053 28th Apr 2017 7:19am
dorsetsmith
key to reading the diagrams
Post #620059 28th Apr 2017 7:56am
stuart123 wrote:
Ah, I saw that!
I've never tried this but I think it is most likely that the engine won't crank, since the starter circuit is enabled by the ECU. It is however possible that the starter circuit is enabled until inhibited by the ECU after engine start, in which casse it would crank but not fire.
Post #620060 28th Apr 2017 8:02am
In the UK that won't stop a determined serial Defender thief since he (or she) will most likely bring a 'generic' ECU with the security features disabled to plug in in place of the vehicle's own ECU anyway. It's a quick way to get round the immobiliser.
That is much more likely to be effective! Thumbs Up
Post #620061 28th Apr 2017 8:04am
Gurmot
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
The thief with a generic ECU is the reason I am looking at putting a voltage where it shouldn't be rather than cutting a voltage from where it should be (as with a kill switch). For example, putting a permanent voltage across the injectors so they won't pulse, would be hard to find if spliced in carefully.
Edit. If the injector is fired by a ground pulse (permanent +12 feed) then a switch putting a constant ground across all pulse connections is what I am talking about. Hard to spot and not quick to overcome.
Post #620114 28th Apr 2017 11:04am
Page 2 of 2 <12
