Home > Maintenance & Modifications > LED indecators side light pack question
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I want to upgrade to LED lights, is it easy to change, and how do I know what relay to change, and which one is it in the fuse box ? its a really simple thing to do, but ive never done anything on my landy, whats the best make to get?
cheers again
Pete
Post #619802 26th Apr 2017 10:58pm
TD5 or Puma? The Relay you can easily find by putting on an indicator and you will feel it click. I have RDX lights and relay. Over the moon with it. You can adjust the flash rate on a knob on the relay. And also fine with trailers too. Set the relay at engine running voltage too. Especially if on a puma. 👍🏻 ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #619818 26th Apr 2017 11:31pm
corgi1
steve, thanks matey what make did you get, what do you mean by set the voltage ?
Pete
Post #619820 26th Apr 2017 11:39pm
corgi1
oh yea sorry forgot its a puma 2.4
Post #619821 26th Apr 2017 11:40pm
When the engine is running charging current voltage with the alternator running will be around 14 - 14.2v.
At rest the voltage without the engine running viltage will be around 12 - 12.4v.
The Electronic relay's are quite sensitive and as you will be using your indicators etc with the engine running set the flash rate with the engine running at that voltage.
That will give you the best flash rate and at a point just enough to turn of the trailer light on the dash.
(You adjust the knob just enough to stop the trailer light in dash flashing all the time with indicator on.
It should flash once if not at all only.
And flash if a trailer indicator load is present only.
Thumbs Up
I have RDX, I believe the Relay is the most popular and I have the RDX lights too.
Although the Wipac are good too.
Just my choice abs I've been very happy.
Bear in mind Brendan also dies LED side repeaters too you may be interested in. Thumbs Up ____\We|Will|Win/___
Post #619864 27th Apr 2017 10:08am
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I fitted Perei LED 95mm NAS style indicator
lights today along with the RDX relay.
The procedure for setting up the relay was to switch on hazard warning lights then rotate the RDX ant - clockwise until the trailer light stopped flashing this did not happen.
The engine was running whilst doing this.
Anybody else experience this?
The trailer light does not come on when using indicators normally.
I have yet to try plugging in the trailer lights. 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #720882 1st Aug 2018 7:45pm
