![]() | Home > Technical > Fuel tank vent line (tdci) |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
I added some more to mine and ran it up to the bulk head. This topic got quite a lot of discussion on the forum. 1982 88" 2.25 diesel
Cheers Spud. I did a search before I posted but couldnt find anything? Can you point me in the right direction?
http://www.defender2.net/forum/topic2067.h...l+breather
Check out the above for starters. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
http://www.defender2.net/forum/post17457.html#17457
Here's more. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Thanks again spud. Not sure why I couldnt find it.
I saw your explanation of extending it. The problem I have is that due to the aux tank I cant actually get at it to add a hose or to snip it back etc. Also because its the highest point, whats obviously happening is that it's twisted towards the front and is at the highest point, so if I fill to the brim, some fuel will run down it, then along the chassis rail and just sit in the tube. Mind you I guess that's not a massive issue since in the event of a lot of expansion it ll just push it further down the pipe. hmm |
Have not lifted my carpet from the rear so I do not know how the floor is fixed in place. If it's riveted you could remove the floor and gain access that way but it seems like a lot of work. I just extended mine to stop water ingress but yours seems to be fairly o.k. where it is. I have no doubt that someone on the forum will be in touch with a solution. That extra tank is a great idea, wish I had thought of it! 1982 88" 2.25 diesel
I think it needs extending, particularly if wading. The tank is a safari equip one for a 90. gives me an extra 125 miles ish. no way i d try to fit it myself, it took them a long time.
jav-uk Member Since: 29 Mar 2010 Location: Shropshire Posts: 112 ![]() ![]() ![]() |
I had the same problem and posted on this last year. Stealer changed the breather valve at the 12k service. They advised it was common problem. Do 3-4 a month, Faulty batch of valves..... Etc..... If your in warranty get the stealer to fix it. I must admit the pipe does look very short on the latest defenders. Paul
Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
how are you guys ataching your breather extentions ? i want to do all mine, gear box, axles and tank up through the snorkal, not because i'm planning any DEEP wading but more a case of more is better when hydro lock or emulsified EP 90 for my diff's, the issue is the join will be the weak link so i dont want to do a half arsed job with duck tape, any ideas,
p.s i was just thinking of adding on to exsisting ones and not removing and replacing with longer. |
Existing ones? as far as I know there are no existing ones (unless you've fitted them). The gearbox breather is a problem, I'm fairly sure you have to drop it to get the breather on there.
Also not sure how you would get them into the RAI without compromising the seals between wing/pipe/airbox. Why not just run them up into the engine bay then cable tie them there? Unless you're planning on going in water which is going to come up to bonnet height inside the engine bay, which will undoubtedly lead to other issues anyway? |
big mike, i dont know but i assumed that the gear box would have a breather, there are two in the engine bay and at first look they seem to be front axle and gear or transfare box. regarding the snorkal, that was paid for when i thought the dealership would do a quality job
Apologies for the delay, hope this helps.
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Cheers Spud, appreciated.
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
not sure if it's any help but there's a pic of the new breather in one of the pdfs in my gallery (Fuel Tank Removal about P7). Mine's the old style and I clipped it up out of the way behind the plastic panel in the n/s wrear wheel arch.
