![]() | Home > Maintenance & Modifications > Chassis to Gearbox earth |
| Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467
I always make up my own, a bit of heavy copper braid, or 25 - 35mm cable, and a couple of copper tube ring terminal lugs and you're done.
| zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720
PRC2015, PRC5499 or PRC3625.
It's not clear which one is which. But none are anything special and you can make your own up to a higher spec for much less money. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
| Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527
Thank you Clive and ZSD I thought it might be easier to do one myself.. I shall have a rummage in the garage. 1993 200Tdi Defender 90
Thanks.. I had seen that.. pricey! 1993 200Tdi Defender 90 |
pricey your not wrong there
Make your own one to army spec I.E crimp terminal lugs and then solder them and heat shrink sleeving on top |
There are a few military ones on ebay.
| All times are GMT |
