Home > Maintenance & Modifications > More investigation needed
itolond
Singapore 1997 Defender 110 300 Tdi SW Alpine White
Hi Forum,
on dismantling the wings for engine ara access i noted the following - what is the best way forward ( i thought these were alum ??
Post #619071 24th Apr 2017 10:59am
hi, that's is the footwell, which is steel. QRZ 2e0vpf
Post #619088 24th Apr 2017 12:21pm
itolond
Best practice is to replace the footwell?
Post #619098 24th Apr 2017 12:47pm
Balvaig
It depends on the rest of the footwell and what repairs you are doing. If that is all the corrosion, then no need to replace, just treat the rust and repaint.
Easy way to check what is steel or aluminium is to use a magnet.
Post #619112 24th Apr 2017 1:31pm
itolond
ok goto it - it doesn't look very bad at all but if i have it apart i was considering the job
i am guessing if steel i can weld a plate over if need be
Post #619132 24th Apr 2017 3:03pm
miker
I wouldn't count that as severe at all! Personally I'd treat and repaint
Post #619194 24th Apr 2017 6:33pm
itolond
Ok lone weekend and i managed to find time the lift the flooring and some of the soundproofing - and it revealed more rust than expected - for long term use - replace footwell
if replace - anyone have a guide - cut pots, weld /rivet and seal - gotchas?
Post #620490 30th Apr 2017 9:24am
