Home > Maintenance & Modifications > Clutch Spring mod
dioliahary
Clutch Spring mod
I came across this mod tonight, is it worth doing and can you do it to a 1990, 90 Confused
Post #618029 19th Apr 2017 9:09pm
Martin
Site Admin
If your pedal currently has the long coiled spring fitted, you will need a later clutch pedal. Good mod though, done it to the soft top Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #618030 19th Apr 2017 9:11pm
hafman
Could you give some more details? I have a 1999 Td5 and to be honest I find the clutch heavier than is good for my left knee Embarassed
Post #618051 20th Apr 2017 4:28am
Here you go. The search function is your friend:
http://www.defender2.net/forum/topic6616.h...spring+mod Darren
Post #618069 20th Apr 2017 7:27am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
I fitted a Britpart clutch assist thingy the other month, one of the better upgrades/mods i've done.
It's one of those 'why didn't I do this earlier' type situations. TD5 Defender 90
Discovery 3 HSE
Post #618114 20th Apr 2017 11:37am
dioliahary
I have checked and unfortunately have the old style clutch pedal Big Cry
Post #618239 20th Apr 2017 8:12pm
Mo Murphy
It's dead easy to swap for the later type.
50 Shades of Pennine Grey
Post #618280 20th Apr 2017 10:36pm
dioliahary
Thanks, do you change the pedal or the whole unit
Post #618301 21st Apr 2017 7:09am
dioliahary
Post #618315 21st Apr 2017 8:14am
Mo Murphy
That would do it. Yup, swap the whole assembly out.
Post #618335 21st Apr 2017 9:11am
dioliahary
Thanks Mo, would I need the modified spring for this unit, the spring on it kinda looks similiar to the uprated vesion .h
Post #618344 21st Apr 2017 9:33am
Martin
Site Admin
No, these pedals are already fitted with the spring.
You don't need to change the clutch master cylinder over either, you can use your existing one.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #619129 24th Apr 2017 1:55pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Did mine last weekend no spring on it at all, much better after and the tie wraps worked a dream
Post #619251 24th Apr 2017 7:44pm
