Home > Puma (Tdci) > Fuel economy
Page 2 of 5 <12345>
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
A little less for me in the 110 Confused
Post #61737 1st Mar 2011 11:15pm
BigRuss
willy eckerslike wrote:
Russ, Brought it up to Aberdeen with me so I'll get an MPG check when I fill up to go home. I got 393 miles on first tank til light on and 410 on second.
But what speeds were you doing??
When you back on the beach? Russell
2011MY 110 XS USW Black
Post #61738 1st Mar 2011 11:23pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
one time i made 452mls/730km www.newfoundland.gr
Post #61740 1st Mar 2011 11:34pm
pannawonica
Australia
I am getting 9 litres to every 100km, this with only 1000km on the engine. To say I am well pleased is an under statement.
My belief that it should improve as the motor loosens up.
Previous Disco TD5 always 11 litres to 100 km, Disco V8 model 2a yes well that another issue. Laughing
Post #61762 2nd Mar 2011 2:19am
draymond
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I am getting the same as pannawonica since new in the City, terribly backward 10.9 - 11.5 on the freeway (at as steady as I can hold 110km/h).
Post #61765 2nd Mar 2011 7:18am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Russ. The first two tanks were round my local area which as you know is rural and hilly, so thats what surprised me when I brimmed the tank and took the figures. The current tank has taken me from my home to aberdeen 324miles on a mix of A roads and motorway, (came up the A697). On the motorway I've been sitting at between 60 and 70mph, so it will be interesting to see what I get when I fill up on the way back down (still got over 1/4 tank left). I'll be heading downhill on the 9th Original Member Pie n Pea Club.
110 HCPU Tipper
Post #61775 2nd Mar 2011 9:01am
bob neville
Just filled up and got 27 mpg out of the last tank full. Mix of A and B roads, 70 mph on dual c/ways.
Most recent trips have been a max of 20 miles or so.
Bob
Post #61858 2nd Mar 2011 8:04pm
mse
If you look on my post a few weeks ago.
Scotland and back with highlands roads 2000miles mixed all types of speeds and roads - changing the MAF and i got between 27-28mpg.
Highest in the puma...30mpg for me.
Lowest at its worst time of playing up 22/3mpg - so i would say anything lower than 22 is bad and 27 is the target with 30 being good. Mike
Post #61859 2nd Mar 2011 8:14pm
vinsell
Italy 2008 Defender 90 Puma 2.4 SW Zermatt Silver
I make 9 km/liter in everyday use now that I have 44000 km on the clock.
At the beginning was better: more than 11 km/liter. Do You think it's time to change MAF?
Vinicio
Post #61896 2nd Mar 2011 10:12pm
jst
last fill was 29.6, previous fill was 30.0mpg
being as accurate as you can filling to the same point on the neck etc. mileage off the speedo NOT GPS mileage. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #61901 2nd Mar 2011 10:48pm
mse
Mileage and position on the neck, doesnt matter hugely - you need more than 2-4 tank fills to assess the impact, it also helps to do complete fills 1/2+ not partial fills.
I think the MAF is a way to go - plus clearing any logged faults.
Any measure of mileage and fuel fill as long as its consistent should build you a picture of pre and post any changes.
Also check the simple things - handbrake rub, tyre pressures etc. Mike
Post #61912 2nd Mar 2011 11:39pm
Naks
At the beginning as better: more than 11 km/liter. Do You think it's time to change MAF?
That, and your EGR may be a bit clogged by now.
Also use some diesel injector cleaner in your next tank, it will remove any soot deposits on the injector tips --
Post #61921 3rd Mar 2011 5:46am
mse
If im honest i dont think a clogged EGR is a massive impactor on MPG.
Think of those who blank, restrict or remove it. I do believe that logged EGR faults, default the ECU and you get a decrease in MPG...but not any failure or restriction of the EGR itself.
Injector cleaner is another good one to try Mike
Post #61934 3rd Mar 2011 9:14am
willy eckerslike
I think the MPG is a good indicator of general health, there are always exceptions but in general a drop may indicate problems starting to develop. Most Land Rover owners are pretty switched on mechanically and will notice small changes in the general running of the vehicle it's a shame the dealers don't recognise this. Hopefully Pete (BAS) will have some more info on the engine set up soon. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #61935 3rd Mar 2011 9:27am
jst
this the main reason why i keep an eye on mine. 27.7mpg avg since new in 3k miles. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #61945 3rd Mar 2011 10:12am
Page 2 of 5 <12345>
