Home > Td5 > Engine mounts.... oil filled?
Td5 engine mounts, the round metal based things.
Are they oil filled? whilst under my 110 just now topping up gearbox oil and greasing the props, I noticed that one of the mounts has what looks like to have had a major oil leak! (well, black fluid), coming out of the top of it and enough to drip onto the axle casing.
the other mount has a slight bit of black stuff, but not as much.
Looking from up above there's no sign of anything above the cast engine mount itself (so nothing has leaked from above "down"),
Has anyone had this before? vibrations don't seem any worse, although this could have been a gradual thing so maybe a new pair of mounts will make things nice and smooth.
Cheers all
Post #616980 15th Apr 2017 1:01pm
dorsetsmith
rubber and neoprene
Post #616990 15th Apr 2017 2:29pm
ibexman
you sure its not dirty oily water Jim Whistle
Post #616994 15th Apr 2017 2:55pm
Nah don't think it is, looks more like a leak than just dribbled out water.
I'm wondering if the neoprene has started to break down and the heat of the engine is softening it and it's oozing out.
Post #617028 15th Apr 2017 5:58pm
hank
I asked this question too. Still not sure of the answer!
www.defender2.net/forum/topic50097.html
Post #617231 16th Apr 2017 2:16pm
Hmmm interesting thread that one ^^^^ just like mine, an "oil leak" from the mounts.
Driving it yesterday there's definately a slight more vibration to the engine... think I'll get a couple of mounts and see how it improves.
Post #617358 17th Apr 2017 7:53am
roel
So I assume you didn't change the oil at the given interval? Whistle Roel
2003 90 Td5 (2009-now)
Post #617615 18th Apr 2017 10:03am
hank
Will be keeping a keen eye on whether it solves the leak!
Post #617640 18th Apr 2017 11:11am
