![]() | Home > Td5 > EGR Cooler Coolant Hose Bypass |
Hold fire I am drawing my coolant today, will have a look for you...
adeparko Member Since: 13 Feb 2015 Location: West Lothian Posts: 41 ![]() ![]() ![]() |
That would be great, thank you
No problem at all will be end of the day though when I come back in
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
Since your there, would you be able to measure the diameter of the coolant pipe rubber hose thats runs into the oil cooler?
![]() Click image to enlarge PBH listed on there ![]() ![]() |
Dear lord anyone else... Got a job on yer know
,photos uploading... Hold fire gents....
Here you go adeparko. the measurement was of the metal pipes OD. The inlet and outlet are the same diameter. ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Hi bankz5152 here you go. The pipe has two different OD. So a reducer pipe. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Thats amazing, thank you so much for the help
Amazing! Top fella, cheers!!
Anytime gents. Good luck with your repairs...
