Home > Technical > Refitting a double cab hood to back of tub.
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi All,
It's been many years since I had my hood on my double cab, and thought I'd put it 'up' for a few days, before I fit out for Summer camping mode.
Unfortunately my memory fails me, and I don't recall how the hood fits to the back of the cab:- the rear drip channel is there with a plastic insert, but bottom skirt of the hood doesn't appear to have any way of fixing it into the channel. Am I missing something? Looked on web and couldn't find a fitting.
Also Exmoor have clamps in their kits, which I certainly don't recall having?
Any pointers/photos would be helpful.
Thanks
Rob
Post #616247 12th Apr 2017 10:30am
hank
There's a 'retaining strip' that clamps the hood onto the drain channel using dzus fasteners
https://www.landroverworkshop.com/diagrams...xing_52698
Post #616255 12th Apr 2017 10:48am
DC101
Hank,
Thanks for the quick reply. I don't recall those at all, but will google:- I wonder would it be different for an 03 model?
Post #616262 12th Apr 2017 11:29am
hank
Don't know, but the exploded diagram looks the same for TD5 and Puma
Seems as though you're missing these
http://www.exmoortrim.co.uk/our-models/def...annel.html
http://www.exmoortrim.co.uk/our-models/def...-hood.html
Post #616341 12th Apr 2017 4:58pm
DC101
Thanks Hank again for the links and time. Very helpful. Definitely missing those parts. I'll search further for an image of how it all fits together.
Post #616435 12th Apr 2017 11:07pm
hank
My hood isn't fitted either but will get some photos of how it goes back together tomorrow
Post #616442 12th Apr 2017 11:17pm
hank
So as we established the 'Drain Channel' is pop riveted to the rear of the cab and the 'Retaining Strip' slots into the canvas hood and then fastens the hood to the drain channel with 1/4 turn Dzus fasteners.
The orientation of the Retaining Strip is shown in the following link, you will also notice it has four slots and four holes. https://www.landroverworkshop.com/diagrams...xing_52698
Drain channel shown on the left, Retaining strip shown on the right...
The retaining strip is basically a length of angle aluminium and slots into a 'channel' sewn in to the front of the hood. The four slots I previously mentioned in the retaining strip locate the retaining strip in position around stitching in the hood. This will make more sense when you look at it than it does in writing...
From outside the hood (the retaining strip has been rotated almost 180 degrees for the photo)
From inside
The following two photos shown the Retaining Strip fitted to the Drain Channel with the 1/4 turn Dzus fasteners. So the canvas 'channel' sewn into the hood would be vertical inside the Drain Channel
This is really difficult to explain in writing but if you have parts 24, 27 and 4no. 26 & 29 from the landroverworkshop link then that's all you need
Post #617724 18th Apr 2017 5:26pm
DC101
Hank,
That's brilliant. I can see and understand now what exactly I'm missing. Pricing it up, it also doesn't look too expensive to finish the set up (though some other related parts are ridiculously priced for what they are). Thank you for all your time.
Rob
Post #617944 19th Apr 2017 6:02pm
hank
No probs. The only thing left to fathom is where your original bits went! Laughing
Post #617958 19th Apr 2017 7:33pm
