![]() | Home > Td5 > Warning light for choke on my 2000 MY Td5 110 |
It's not simple pins with bulbs:
I had a small problem with mine giving strange lights ![]() Click image to enlarge one plug disconnected: ![]() Click image to enlarge I fixed this with a small bypass. ![]() Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6691 ![]() ![]() ![]() |
Apply a ground to pin 2 of the 16 pin connector to illuminate the choke symbol.
I've used the same symbol as a warning lamp for my diesel transfer pump (front to rear tank). If you need to convert a positive feed to a ground use a relay or a transistor driver (I've done the latter). Roel you do indeed need to bridge some pins on the panel to extinguish the ABS and brake fluid warning lights. This is done on the loom on factory cars. ![]() ![]() |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Thanks Martin, I'll give that a try 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Martin.. been trying for a while. Never done this before, is this correct?
![]() Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
Yes, looks right to me
Got it all working finally. Thanks for the assistance. Unfortunately later today I left my iPad on the front wing (using the diagram as a reference)... I went to the market and lost my tablet on the drive there.
![]() Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 ![]() ![]() |
If you have iCloud on the iPad then you can log into iCloud.com from any computer and it will locate your iPad as soon as it connects to a wifi network (or instantly if you have a 4G sim in it).
Thnaks, did that andset it up to wipe it as well. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
