Home > Td5 > 2003 TD5 differential drain/fill plug?
RF3777
Hong Kong 2003 Defender 110 Td5 USW Corris Grey
I'm trying to change the diff oil recently, then I discover the fill/drain plug is plastic, I'm a bit scare looking at it, since the plug is a bit deformed...
I think I will need replacement right after remove them out!
May I ask if anyone knows the parts number, or alternative plug from xbay?
Many Thanks Bow down
Post #615959 11th Apr 2017 7:49am
dorsetsmith
Land Rover Defender Differential Drain Plug 608246
Post #615971 11th Apr 2017 9:13am
roel
Check if the disco2 one has the same thread as they have a magnet build in. Roel
2003 90 Td5 (2009-now)
Post #615974 11th Apr 2017 9:30am
dorsetsmith
OR
Corresponds to Land Rover part TYB500120,TYB100070, TGZ500070 alternative part for 608246
Post #615976 11th Apr 2017 9:37am
RF3777
Thank you everyone, are they both fill or drain actually the same thread?
Xbay has list a set of 4 plugs for Defender, they look the same!
Post #615979 11th Apr 2017 9:57am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
The drain and fill plugs are the same on mine.
Post #616016 11th Apr 2017 12:14pm
RF3777
Thanks! Bow down
Post #616062 11th Apr 2017 2:58pm
