Home > Td5 > VDO Water Temperature Gauge
geobloke
Well. That didn't work... Shocked Rolling Eyes Big Cry
So I bought a VDO water temperature gauge (with numbers) to replace the standard TD5 unit (with no numbers) thinking that there is a good chance it will be a straight swap...
Nope! Turns out the LR TD5 water Temp Sensor is not compatible with this gauge. Actually surprised me considering the VDO nature of the LR gauges.
Guess I will have to think about fitting an auxilary sensor in the coolant system to get this working...
Gauge reading
Nanocom reading...
Big Cry Big Cry Rolling with laughter Rolling with laughter Oh well... So close, but no cigar...
Post #615177 7th Apr 2017 5:22pm
paullo
Canada
I'm more curious about the VDO Tacho you've got installed! I'm really keen on getting one fitted in my TD5 but the current cost of the LR branded ones is too steep.
Post #615359 8th Apr 2017 4:51pm
roel
On the td5 the gauge is ECU controlled, so no direct connection with the sensor. Roel
2003 90 Td5 (2009-now)
Post #615360 8th Apr 2017 5:02pm
geobloke
That'll be why then. Worth the try. Sensor on order to get it working, love numbers on gauges. Somehow seem a bit pointless without them, no?! Wink
Post #615874 10th Apr 2017 8:39pm
miker
Numbers on gauges make people worry! The normal gauge basically indicates "cold, warming up, normal, Oh crap"
Post #615879 10th Apr 2017 8:46pm
geobloke
Post #615901 10th Apr 2017 9:46pm
roel
That's correct. I see the first half off the gauge working but never seen 3/4-ers hot. It is working temp and maybe a little warmer and then straight to very hot. (and reduced power) Roel
Post #615973 11th Apr 2017 9:25am
geobloke
Post #617040 15th Apr 2017 7:16pm
fourwzzy
Russia
What is part number of THIS gauge? Can't find anything with td5 style white arrow, not red!
Thank you!
Post #709486 27th May 2018 10:53pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
If it does move but doesn't match, you can change that in the ECU to make it match.
Well that does require some detail on the reference voltage to that of the temperature on the gauge and it can all be resolved. You just need to adjust the temperature gauge settings in the ECU to make it do what you want.
On a Td5, from 88 to 105 deg, the ECU drive to the gauge is programmed not to move, so you don't get alarmed, but it goes up like a rocket after 105 to 140, which is way too late.
So i've actually adjusted the table in the ECU to make sure the gauge moves during the climb between 88 to 105 to make sure it's more realistic.
So back to your issue, if it's moving, it can be resolved, but you require some reprogramming of the ECU to take care of it, but it's not very easy to do.
The Td5 will reduce the amount of fuel based on a multiplier factor at certain temperatures as well. So you only want to correct for the gauge reading but not the ADC value from the temperature sensor.
Hope it make sense. The defender has migrated, leaving the owner behind.
Post #717477 13th Jul 2018 10:53am
Martin
Site Admin
If you want to change the Td5 gauge the best thing to do is leave the original sensor in place (the ECU uses it as part of the fuelling and start strategies).
Add another sensor wired directly to your chosen gauge - then you can use the correct matched sensor for the gauge.
You can get pipes with a sensor boss ready fitted/tapped - add this to the top hose.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #717479 13th Jul 2018 11:03am
miker
Interestingly my temp gauge has recently developed an inverse relationship with the throttle pedal. The harder I press the pedal, the lower the gauge reads! Nanocom still reads normally though...
Post #717721 14th Jul 2018 8:24pm
fourwzzy
Russia
guys what is part number of topicstarter's vdo gauge? looking for exac same model with white arrow, not red
Post #766019 29th Mar 2019 10:40pm
geobloke
Hi Fourwzzy. The gauge has the following part number inscribed in to it;
310.284/8/3
VDO 12v
02.95
Hope that helps
Post #767736 8th Apr 2019 9:35pm
ericvv
Martin wrote:
Add another sensor wired directly to your chosen gauge - then you can use the correct matched sensor for the gauge. You can get pipes with a sensor boss ready fitted/tapped - add this to the top hose.
Here’s an example. Exists in various diameters to suit specific coolant hoses.
https://www.ebay.co.uk/itm/32MM-Car-Water-...Swq4la8-xr You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #767772 9th Apr 2019 5:02am
