Home > Off Topic > Welded Mesh
Keith5
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Welded Mesh
Definitely off topic.
The voting majority in the house have decided that we are missing Rabbits from our lives, not for eating but as pets. As such I've been tasked with building a run to compliment the hutches.
Looking around I've got some info that points me in the direction of building a wooden frame (approx 4ft high) utilisng a spare bit of garden approx 10ftx8ft. welded mesh is the recommended material for putting inside the frame and I suspect that as I will require a 36ft long 5ft tall strip (1ft to be buried) I am going to be best buying a roll of it. The excesss could be used to cover the top.
Are there any recommendations on where to get this from (suspect it will be wanting galv rather than plastic coated). Also any thoughts on gauge of wire to be fox proof?
Thanks Keith
Post #615753 10th Apr 2017 12:43pm
Mesh direct. Thumbs Up
And timber wise I've used 34x34mm Wickes planed softwood. (Must be treated / wood preserved.)
The Mesh Direct site will inform you as to gauge etc.
Don't use chicken wire though, use weldmesh typically the square 1" hole stuff is stronger.
Bird cage wire and chicken wire are too weak.
Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #615763 10th Apr 2017 1:18pm
In the past I have always bought weldmesh from our local agricultural merchant (Mole Valley Farmers in my case), so I suggest your local ag merchant. 2mm with 50mm squares will be fox proof, but only if roofed. A fox will also dig under the fence, so you'll either need to go a foot or so into the ground or mesh the floor for a foot or so along the fence, preferably on the outside.
Alternatively keep some alpacas with the rabbits and they'll keep the foxes away.
Post #615782 10th Apr 2017 2:15pm
Keith5
Thanks for the suggestions. I plan to go a foot into the ground with the mesh and backfill with broken bricks and course gravel to try and manage the foxes. Also need to put turf down so was going to put mesh across the whole floor first.
Garden is a bit small for alpacas. Mad
Thanks Keith
Post #615833 10th Apr 2017 6:56pm
gilarion
Check that any treated wood you buy is Rabbit safe as some of the treatments given to wood are poisonous to animals. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #615839 10th Apr 2017 7:20pm
^^^^ True, forgot to add that! Embarassed
I use Ronseal, it won't last forever but it is non toxic. Thumbs Up ____\We|Will|Win/___
Post #615850 10th Apr 2017 7:37pm
dorsetsmith
Post #615855 10th Apr 2017 7:49pm
I quite envy you with this enclosure - the ones I build start 2m in the ground and then extend 2m above ground, with a 1m inward sloping overhang plus hotwire atop that. The mesh is 4mm wire, 50mm squares, the posts are good recycled telegraph poles or 8" pressure treated new posts, and all the timberwork is outside the mesh, so everything is protected by mesh. Over the years I have built many, and currently am planning a 1500 square metre extension to a 500 square metre enclosure. It's blooming hard work, even with a backhoe! So yours should be a doddle by comparison.
Mine aren't for rabbits, though, but something rather larger!
Post #615867 10th Apr 2017 8:18pm
Doc P
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
What? Velociraptors?
Post #615915 10th Apr 2017 10:29pm
There's a clue in my username.
Post #615919 10th Apr 2017 10:39pm
Doc P
Sounds like you don't have to worry about foxes getting in😳
Post #615921 10th Apr 2017 10:45pm
No, that's never happened for some reason ! Laughing
Post #615927 10th Apr 2017 11:06pm
