Home > Puma (Tdci) > Easy to fit oil pressure gauge?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Is it a difficult task to fit an oil pressure gauge in the tdci 2.2?
Im monitoring boost and EGT and have a third spot for a gauge and figured this would be my next one. Batterie already monitored by National Luna system. Just not sure how an oil pressure gauge works and installs
Post #615341 8th Apr 2017 2:09pm
big110
nobody has fit an oil pressure gauge in a 2.2?
Post #615579 9th Apr 2017 7:22pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I've fitted them before in different cars, it's not hard at all, usually all you do is fit a T piece on an oil line and then run a wire to the gauge.
Post #615584 9th Apr 2017 7:38pm
zsd-puma
or screw a Tee into the oil pressure switch hole and screw the oil pressure switch and gauge sender/capilary tube into the other part of the tee.
Post #615696 9th Apr 2017 11:30pm
Merlin
If oil pressure is presented at the OBP then buy an app and watch it on a tablet.
Sadly it isn't on a 2.4 so the Torque app doesn't pick it up
Merlin
Post #615811 10th Apr 2017 5:09pm
