![]() | Home > Puma (Tdci) > Knocking sound from rear undercarriage |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 601 ![]() ![]() ![]() |
You may want to take it back to the dealer as I guess your car should still be under warranty.
I had the same symptoms on my 90" a year or so ago, was a problem with the rear diff, it was eventually replaced under warranty and now knocking is gone. See this thread or this one as well, hope this helps... |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
Diff, driveshaft flanges, A frame joint, trailing arm bushes etc., etc are all possibles but usually confined to high miles / older LR's. At only a year or two old it ought to still be under warranty. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2687 ![]() ![]() ![]() |
drive flanges? Also the MT82 gearbox makes a pretty loud bang when changing gears. --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
reno Member Since: 17 Feb 2011 Location: Singapore Posts: 9 ![]() ![]() ![]() |
Had sent it to my local dealer for this issue and was told that the knocking sound was due to a faulty rear axle.... They refused to carry out the replacement of the faulty part because my warranty for the entire drivetrain and suspension system had been voided as i am using 33" mt tires and wheel spacers.... They claimed that these tires and spacers put additional stresses on the axles and drivetrain....
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
Found a video I didn't know I had...
Roll pin in the rear diff had worked itself loose... |
Thanks for all replies.... Think the rattle in the attached video is quite similar to what i have.... Will get my workshop mechanic to check for any loose roll pin in the rear diff... Hope this is the real source of the rattle....
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
had my rear drive shafts and flanges replaced after reporting the same sound, thats on a 40 ,000 mile 110. also half a dozen upper shock bushes in that time, which can make a bit of a noice. |
