![]() | Home > Td5 > Stuck Fuel Filler Cap! |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
When mine did that it required drilling
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
kyvlle Member Since: 22 Jul 2016 Location: Essex Posts: 73 ![]() ![]() ![]() |
Right. I'm ordering a new fuel cap.
Going to see how I can drill or prise the old cap off! |
Try graphite powder in the key slot work it in with the key manage to get one this way
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
Mine does this every now and then, i find if you pull the cap up while turning, eventualy it gives in!
I will probaly find myself stuck on a forecourt one day not being able to fill it up? Must get a new one too.... ![]() Wanted, Forward Control Anything considered. |
Crisis averted for today at least! I managed to to unscrew the filler cap after pulling up at an angle while turning. The "at an angle" bit is important, it's as if I was trying to pry the cap off -- that got the internals to latch -- and allowed me to unscrew the cap.
When putting it back, one click is fine; two clicks and it's back to being stuck... Hopefully I can pry it off again when the new cap arrives in the post in a couple of days! |
TechnoTurkey Member Since: 25 Jul 2016 Location: Worcestershire Posts: 88 ![]() ![]() |
If you drill then remove the filler pipe from underneath first, stops any debris entering the tank.
