![]() | Home > Technical > Replacing lock barrels (1999 TD5) |
| mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772
The screw screws into a metal insert in the plastic of the handle and as the screw and insert corrode together this causes the insert to break free from the plastic of the handle. If the screw is turning you can pull on the outer Handel at the same time which will remove the plastic bit, then put some grips on the metal insert when it's exposed and try and break the corrosion by unscrewing the screw.
Sorry for the essay but I couldn't think how to explain it quickly My build thread http://www.defender2.net/forum/topic17615.html |
| gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5141
From what I remember when I replaced mine there was no need to remove the handle. The barrels are just secured by a small screw at the back - remove the door card and inner plastic liner and you'll see it. Prize off the little clip that holds the linkage and detach it. Then remove the screw and the barrel comes out from the outside of the door. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
| hafman Member Since: 28 Mar 2017 Location: W Sussex Posts: 81
Thanks both, especially gilarion for your tip re: small screw on the inside of the lock barrel. Saved me loads of time not having to actually remove the handle
I've now done the ignition barrel and 2 of the three doors, and tomorrow I will complete the task; having to only have one key for all four locks will be a dream |
| All times are GMT |
