Home > Defender Celebration Series & Classic Works > Air filter replacement.
masmia
Australia
Just had 40,000klm service (2nd) and air filter was 'inspected and cleaned' . Checked 1st service docs and air filter was 'inspected and cleaned', is this correct ? I wonder how many times you can clean a paper element filter before it is useless.
It was a Landrover dealer servicing Neutral
Post #615115 7th Apr 2017 11:54am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Depending on conditions I have cleaned paper air filters multiple times, by cleaned I mean I remove the air filter and used an airline to remove the dust, driving through sand and dust will clog a filter quickly and regular cleaning is important.
*when cleaning an air filter with an airline make sure you blow the dirt out of the filter and not into it Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #615126 7th Apr 2017 12:19pm
shaggydog
Or you could put a brand new one in?
Why bother cleaning it if you have already removed it?
Seems a bit backwards to me Confused Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #615132 7th Apr 2017 12:56pm
Shouldn't be cleaned, it should be replaced.
Relatively cheap, and removing and refitting the same filter give a higher likelihood of contamination.
Sure, you can brush it off a little on the inlet side carefully.
But that is purely a regular maintenance thing, they should IMHO be changed no later than every other year.
I sometimes change it every year depending on condition. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #615159 7th Apr 2017 3:50pm
