![]() | Home > Wheels & Tyres > Hutchinson Offset/wheel Question |
Depends on the size of tyre you plan to fit rather than just the wheel. Darren
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
The 8j would allow for a wider stance as they will take wider tyres Cheers
We are running 255/85/16 BFG M/T on Hutchinson beadlockers on a 90 with standard suspension set up.
Can not remember offset but think it is 0 Suggest you contact Nakatanenga for advice. Brendan |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
8j sold out!
7J can be used with the usual tire sizes up to 255/85 without lift. WANTED: SII or SIII in max 1.5k |
Wider rims take wider tyres as above, if you want wide stance get wide rims. If you want diff height clearance then fit same width to narrower rim. Cheers
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
I have 16x9 0 offset with 285 75 16 fitted to a completely standard 110... No issues.
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 391 ![]() ![]() ![]() |
thx all for the assist.
