![]() | Home > Maintenance & Modifications > Roofs: to Dynamat or not to Dynamat? That is the question! |
Having recently ripped out the manky carpet that had been glued in place by the previous owner and just picked up a front head lining for a bargain price, my thoughts have turned to insulating the roof. I've got some big sheets of self-adhesive closed cell foam to stick up but I'm not sure if it's worth fitting a sound absorber, too? Since removing the carpet, the roof has a distinct 'bong' when closing the door, but will this be resolved with just CCF and a headlining?
What's the consensus? (Incidently, I've got a box of Silentcoat to hand but it didn't sound (ha!) as slick in the title) Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
I wouldn't bother if you're going to put up foam and the headlining. I would concentrate on the floor and bonnet?
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
I’m going to dynamat mine when the headlining is down. My thinking is it WILL help in some way- (especially after finding the difference in doing the front of my car) and I won’t want to take the headlining down again in the future to dynamat it. My 90 Project : http://www.defender2.net/forum/topic52774.html
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3854 ![]() ![]() |
Hello
I've done other bits of my car and its made a huge difference, As your headlining is off and you have a box 'spare' its a no brainier I would do it. I will do mine at some point but I hear its quite awkward removing the headlining in a 110 As other have said it will probably also keep it cooler in summer and warmer in winter ![]() |
Thanks, all. A bit of a mixed bag on the responses so I suspect I'll stick some Silentcoat in the middle of the panels whilst I've got the chance. Darren
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 ![]() ![]() |
If you have the lining off anyway, I'd stick as much as you can up there. It does make a huge difference so why not do it?
I did mine with dynamats lighter version and it does take out a lot or noise, you also get that nice solid sound when you knock on the roof
![]() 2011MY 110 XS USW Black |
