Home > Off Topic > Gaffer tape residue
Page 2 of 2 <12
Bluest
I am a fan of good old White Spirit for the removal of sticky, gluey stuff. In fact, I removed some gaffer tape residue with it only this Sunday, although the tape had only been on a week in this case.
Try on an inconspicuous area first, it's usually ok on most things, but you never know. 2007 110 TDCi Station Wagon XS
Post #614502 4th Apr 2017 5:19pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Autoglym Tar remover works well for most adhesive residues. https://www.autoglym.com/intensive-tar-remover
Post #614566 4th Apr 2017 9:57pm
Rup90
Agree with above - Autoglym intensive tar remover is highly rated or if you need something stronger try paint thinners (be careful with it though).
Post #614569 4th Apr 2017 10:05pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
https://www.amazon.co.uk/Ambersil-31629-La...el+remover
Another "citrus" label remover that works well and is easy to obtain.
Post #614575 4th Apr 2017 10:28pm
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Ok thanks for all the options. So far wd40 nothing. Carplan brake cleaner nothing. Heating it as much as I dare and a scouring pad in hot soap water, best so far for the actual dirt but marginal on the residue. I'm in town later so will have a look at getting some of the other things mentioned. Thanks. Rhubarb and custard let fly with their secret weapon.
Post #614597 5th Apr 2017 5:44am
Isopropyl
Post #614616 5th Apr 2017 7:41am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
All this talk of solvents in the cab it would now be suitable to throw a match in and then go back to the best small lorry in the world. Job done.
All meant in jest Lambert.
Go to your local pvc window suppliers and get a bottle of solvent - it works.
If you do go down the route of first suggestion then there is a lovely looking truck cab 300 tdi on carandclassic.co.uk. Local to you as well.
Post #614666 5th Apr 2017 1:06pm
lambert.the.farmer
As an aesthetic thing a 90 pickup one of the most agreeable things ever to look at. But I don't need to own one to look at it. Cool Rhubarb and custard let fly with their secret weapon.
Post #614718 5th Apr 2017 7:25pm
Page 2 of 2 <12
