Home > Maintenance & Modifications > SVX lamps? |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Mechanically yes, I think they're pretty much a straight swap but electrically no. The SVX crystal headlamps contain the sidelights whereas the originals do not so there are some wiring changes required.
Also, if you're going for the complete SVX set up, you get driving lamps too which come on with your main beam. To sort this out (and the sidelights) the kit comes with an additional wiring harness and relay to make the necessary connections. Pete |
28th Feb 2011 11:57am |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 |
Thanks for that.
I'm actually just looking to improve the main beams - but the whole setup is intriguing. |
28th Feb 2011 12:22pm |
mrandmrsh Member Since: 31 May 2010 Location: Huddersfield Posts: 692 |
I have got a bit confused looking at the prices.
The RHD with h/l adjustment is VPLDV000 and RRP is £408 but do I also need the grill as a separate? It seems strange that the lights and gubbins is £408 and the grill (moulding kit) LR008361 is over £500. So for the fancy lights and grill it is going to be over £1000 fitted. Has anyone who has done this found decent sources? Regards Craig |
28th Feb 2011 12:49pm |
Yes, you do need the grille kit, which comes as three parts (the centre and the two headlamp surrounds). You also need the wiring kit and fixing kit, and the prices for all of these in the brochure are plus fitting.
There's a guy on eBay here: http://cgi.ebay.co.uk/Land-Rover-Defender-...3f072b97a5 doing the whole lot for £1120 ish plus delivery. Obviously, then you've got to fit it yourself. In the advert, he lists all the part numbers for all of the bits you need which is useful for research purposes. I ordered my kit to be fitted to my new Defender by the local dealer before I took delivery of the car. It worked out quite a lot cheaper that way. Pete |
28th Feb 2011 4:10pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
And when you have spent over £1500 you will have one ugly car Mike
28th Feb 2011 4:25pm |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 |
I 100% agree and have no aspirations to imitate a gullable purchacer of an inferior car... buy a good XS spec 90 or 110 and make it your own spec.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
28th Feb 2011 4:45pm |
Each to their own, I think on some colours the SVX front looks ok and there is a functional benefit as the standard lights are . However, my pockets don't quite run that deep....
28th Feb 2011 4:56pm |
I suppose black at night, would be an improvement On main beam standard isnt that bad - but for about £50 get wipac clear lights and uprate the bulbs (plus keep the headlamps clean) if your desperate Mike |
28th Feb 2011 6:05pm |
You really don't like the SVX front do you? I've only been a member here since the end of last year, but that's at least the third time I've seen you air that opinion. Some people (me included) really do like it and the lights are a massive improvement over the candles of the standard setup, especially on main beam. Explains your post count I suppose. Pete |
28th Feb 2011 7:38pm |
I suppose the post count has something to do with being a member before the svx was thought up... but no, the svx front end is awful and it will be so until the scrap it...i grant there are a few people who believe it either looks nice or is better...but then there are people with more money than sense too. I would add the old range rover sport body kit was bad too...but then they sell more and make more money to face lift it. Trust me - ive passed my thoughts on direct to the designers but there are reasons for everything Mike |
28th Feb 2011 9:44pm |
lrdxb110 Member Since: 09 Jul 2009 Location: Dubai Posts: 224 |
Personally I don't like the svx front too, just earlier today saw td5 being fitted with a svx front at the dealers, it just look horrible
I don't even like the HST kit on the range rover sport, its just wrong! If you want decent lighting why don't you go for these - http://www.mobilecentre.co.uk/led-land-rov...p-450.html '08 LR Defender 110 '08 Mini Cooper S - Sidewalk '86 MB 500 SL '79 MB 450SEL 6.9 |
28th Feb 2011 9:55pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
just looked at that svx light and grille set up and threw up all over my keyboard
would not have it even if they paid me £1500 |
28th Feb 2011 9:59pm |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 |
I for one like the svx front as I have it on an svx and will be getting it coloured coded
on my new 110. The bottom line on it is that the lights are a huge improvement over the standard candles. I also find it funny when I read "more money than sense" what does this mean ? Is it because someone has money they have none or does it mean you have no money or is it just an insult to anyone who has different taste to you ? |
28th Feb 2011 10:01pm |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
Every SVX owner has more money than sense? Well that has alienated a lot of enthusiastic Landie owners. A variation of anyone who does not drive a Leafer is a softie I suppose. A few IMHOs would change your post from a rant into a perfectly valid opinion. But tell me if the SVX front end raises such contempt, why are you reading this thread? |
28th Feb 2011 10:44pm |
