Home > Puma (Tdci) > waxoil.....thoughts
bear100
waxoil.....thoughts
As title really, I want to apply something to my chassis to prolong the life of it
Is the <removed> worth the money? How long has it been on and how does it look? Is it the ultimate in coating?
Wax oil, same questions really
Thumbs Up
This post has been edited by the site administration team to comply with forum policy  2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #614351 3rd Apr 2017 10:39pm
mse
I'm sure this post will be pulled...but all I can say is anything well applied is better than nothing Mike
Post #614363 4th Apr 2017 12:02am
grafty99
+1 ^^ 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #614364 4th Apr 2017 12:04am
Martin
Site Admin
Tons about corrosion prevention on the forum.
Start here: http://www.defender2.net/forum/topic10467.html
I will PM you with why I have removed what I have removed.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #614365 4th Apr 2017 12:06am
zsd-puma
Waxoyl is cheap and effective at stopping rust. but it's messy, attracts dirt, stinks, melts and leaks out in summer, and it's awkward to apply.
I would recommend Dinitrol, it's a little more expensive, but it's so much easier to work with and lasts much much longer. It's also a system with different products for different areas. Waxoyl washes off easily from wheel arches for example, where as dinitrol do a thicker version for wheel arches which doesn't wash off with road spray. The biggest plus is Dinitrol skins over so it doesn't attract dirt.
Post #614368 4th Apr 2017 1:25am
Roverrobbie
2007 Defender 90 Puma 2.4 HT Keswick Green
I have found that waxoyl tends to peel off. Dinitrol and bilt hamber are better and seem to last well. (Treated the sump of my defender with bilt hamber 6 months ago and it it's still ok) Any of these wax coatings do not seem to neutralise rust very well unless the surface is cleaned and treated first. If they are spayed directly onto rust , they trap moisture and may make the corrosion worse. Any rust should be painted with a good quality rust preventing primer. I have had limited success with products such as Kurust or POR 20 and would not recommend them.
Post #614410 4th Apr 2017 8:41am
Sammyboy
United Kingdom 2012 Defender 110 Puma 2.2 USW Sumatra Black
Has anyone got experience of <snip>
Post #614413 4th Apr 2017 8:49am
I'm afraid that discussion of that company is not welcome here, which, I suspect, is why the original post was edited. Darren
Post #614414 4th Apr 2017 8:52am
Martin
Site Admin
http://www.defender2.net/forum/topic8301.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #614422 4th Apr 2017 9:42am
AMBxx
Discussing <snip> again? Rolling with laughter
Odd - adding snip-snip in brackets gets shortedned to snip
Post #614436 4th Apr 2017 10:27am
zsd-puma
They're ok for soaking into it inside box sections, so long as you can get the car dry the waxes soak into the rust and replace the water preventing it rusting further. Little point spraying/painting it onto rusty bits on the outside mind you.
It's best not to paint rust, if you can clean it off to bright metal first then paint the metal with a decent zinc primer. The rust converters are good for working into seams where you want to paint over it but can't get all the rust out. They're not miracle workers though, if you can clean the rust off with a flap wheel then it's always preferable to using a converter and painting over it.
Post #614468 4th Apr 2017 2:29pm
Roverrobbie
I have cleaned off rust using a grinder and then treated with Kurust and then paint only for it to return in a short space of time. Also Zinc primers such as Galvafroid work well at protecting freshly cut bare steel but are not so good at preventing rust from re-appearing. I have had most success grit blasting rust and then treating the freshly blasted surface with Mebon primer. Then a top coat can be applied. This works very well and can slow down rust for years.
Post #614487 4th Apr 2017 4:16pm
zsd-puma
That's where you went wrong, rust converters make poor primers for clean steel, when you cleaned it off with a grinder you got rid of pretty much all the rust. The primer then didn't bond to the steel properly so it didn't protect it, the converter basically just made a latex barrier between the primer and the steel. I'd made the same mistake myself, applied to brown rust, converters work quite well. But if it's in a location you can clean all the rust off it far better than trying to use a converter on it. If you clean off the rust to shiney steel (flap wheels work better than grind stones) then it's as good as fresh cut steel.
Post #614489 4th Apr 2017 4:30pm
