Home > Tdi > Fuel pump adjustment
simons17
Evening all
Just got the defender back from mot and it has failed on to much black smoke so it will not pass the emissions . The car is a 300 tdi which I believe has had a bit of tuning. I turn down the mixture screw but the black smoke is still present on first press of the peddle. I have read this can be improved by adjusting the boost compensation on the fuel pump.
Any one completed this before and is there any pit fall to watch out for ?
Simon
Post #613886 1st Apr 2017 10:01pm
jst
Which party did you adjust? The smoke screw on top, pin or star wheel? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #613933 2nd Apr 2017 7:59am
simons17
I have just adjusted the torque bit on the top with a combo of the mixture screw on the side .
On the top torque bit I turn it counter clock wise by half a turn . The smoke has reduced.
Does this seam about right or would you go further ?
Post #613964 2nd Apr 2017 11:04am
jst
the mixture screw? you mean the full fuel flow screw on the back of the pump? with the anti tamper.
torx - smoke screw - too much here would give black smoke from immediate pull away, so if smoke worse just as you start to accelerate then back off another half turn.
diaphgram inside is the real one you need to adjust so it gives less fuel for boost ratio. its under the 4 screws holding the top on. there are probably marks on it where the needle used to rub on the profile. turn it back to this shallower profile.
i take it air filter is clean? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #614266 3rd Apr 2017 6:11pm
jst
https://www.defender2.net/gallery/albums/u...ev%202.pdf
should be of use Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #614268 3rd Apr 2017 6:13pm
simons17
Thanks for the help; this is great info, Ill give this a go
I managed to get it through the MOT with a bit of fiddling.
Ill change the filter as a precaution but it doesn't look bad.
Simon
Post #614283 3rd Apr 2017 6:55pm
