Home > Maintenance & Modifications > Fitting Td5 tub to 1989 V8 90
ami1971
Hi guys I've purchased a Td5 rear tub to replace on my 1989 V8, but I want to meet the tank in its original place under passenger seat , any suggestions where and how I can connect the fuel filler neck to the tank , does anyone do pipes to convert--any help would be appreciated
Post #614056 2nd Apr 2017 6:15pm
I can't imagine that there's an off-the-shelf conversion available as it not what you'd call a common modification.
By far the easiest solution would be to cut in a filler from an earlier tub - salvage your old one? If you wanted to go the whole hog then re-skin that wing with an earlier pressing to lose the TD5 filler location. Darren
Post #614060 2nd Apr 2017 6:25pm
V8GPC
The 50th Defender has a rear mounted fuel tank.
Maybe there are some parts available off the shelf.
The filler and breather look similar to TD5.
Also 110s have rear mounted tanks of the era; again maybe they have suitable off the shelf items
Post #614377 4th Apr 2017 7:08am
The problem will be routing the filler pipe from behind the wheel to the under seat tank. There won't be any off the shelf parts for that. Darren
Post #614406 4th Apr 2017 8:33am
Romadog
Is it a tub with a bulkhead or without one ?
If its without one I'd be interested in it as I think you need a 300tdi one or earlier to do what you want. Whistle
I have this surplus........
Post #614745 5th Apr 2017 8:38pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
I doubt there's a kit available but you could probably get one made up from a local fabricator or put something together using some silicon bends and some exhaust pipe.
The main thing to bear in mind is that you need to be able to fill it and to do that you'll have to be very careful to route the pipework. You'd need to make sure that it has a good "fall" to the tank at all points and that the filling vent is routed and connected up too.
TBH, especially with a V8, you'd be better off fitting a TD5 tank at the back, they're bigger than the underseat one. http://www.yorkshireoffroadclub.net/
Post #614758 5th Apr 2017 9:02pm
